Learn library SD card question
in Propeller 1
void run_test() { sd_mount(0, 1, 2, 3); FILE *reader = fopen("fat_test.txt", "r"); FILE *writer = fopen("new2.txt", "w"); while (!feof(reader)) fputc((char) fgetc(reader), writer); fclose(reader); fclose(writer); }
The above code should copy a file to a new file.... pretty simple. Unfortunately, when I check the resulting file from my computer, there seems to be an extra byte at the end - 0xff if I understand what gedit is showing correctly. Am I doing anything incorrectly?
http://www.cplusplus.com/reference/cstdio/feof/
Looks like my loop should be
