Motor Mount and Wheel Kit
On the encoder that comes with the kit there are two 3-pin connectors. Are they the same? Is the output just duplicated on both connectors? The reason I ask is that after calibration I see that one week had no encoder ticks. I switched to the connector and I now get encoder ticks. I just want to make sure this is a reasonable thing to do or should I replace the entire encoder pcb? Any information would be helpful. Thanks.
The Motor Mount and Wheel kit does indeed have two 3-pin connectors. The power and ground pins are duplicated on these pins. The output from the encoder is not. The output is two channel quadrature.
Quadrature encoders are very useful with robotics. They can ensure a wheel moving back and forth isn't mistaken for movement in one direction.
There are 36 slots in the encoder disk. This produces 144 transitions when used as a quadrature encoder. You can get pretty precise control from these encoders. Here's the robot I made using this hardware.
http://www.robotrebels.org/index.php?topic=166.0
No, they'll both work the same.
I hope you keep us updated with your progress.
