Test NTSC video frame — Parallax Forums
potatoheadpotatohead Posts: 10,267
edited 2015-10-11 11:22 in Propeller 2
Got somewhere. Not far. I need to know a lot more about the STREAMER and DAC modes, but hey! It's a nice frame. Yes, the code is ugly. Was focused on timings and sync... both of which could be a lot better, but this should display on most devices. I'm curious as to whether it does. Connect composite to DAC 0.
  • Looks good on my monitor. :)
  • RaymanRayman Posts: 16,355
    Just tried it and see a square with left half white and right half gray, all on black background.
    edited 2015-10-11 16:29
    That's it. Nothing fancy.
    I was looking to carve out a rough signal by just plugging values into the DACS directly. Not knowing much about the STREAMER, etc... it was a first step. From here, I plan to consolidate things, test for jitter, see what HUBEXEC does, and so forth. But there needed to be a baseline signal to work from and gawk at on the scope.
    Without WAITVID, I think a good signal foundation is going to need to be interrupt driven so it happens on time, every time, no matter what. Ideally, pixels are bursts from the STREAMER, triggered by key time events in the signal. A driver template would more or less be some code, with a "put your pixel code here" kind of thing in it. Similar to P1, but a bit more complicated to create baseline signals.
    Again, ideally not so complicated for people to provide pixels however they want to do that. Scanline driver, bitmap, etc...
    Use as an object should be very similar to P1.
    Then again, Chip may have a much better plan. Maybe it can be simpler than I envision.
    edited 2015-10-11 16:17
    Strange... I don't see the attachment anymore. Is that just me? Nevermind, it's there now. Weird.
  • pedwardpedward Posts: 1,642
    edited 2015-10-11 21:02
    Pictures, or it didn't happen.
    I think I see how your code works. Now, I know how the new waitcnt works.
    I hope there's a way to use the streamer for this. Think that means finding a way to throttle down the transfer speed. Otherwise, I guess we'll have to stream to LUT and then push out from there.
  • jmgjmg Posts: 15,200
    Rayman wrote: »
    I hope there's a way to use the streamer for this. Think that means finding a way to throttle down the transfer speed....
    IIRC, Chip has said the streamer has a NCO clock scheme ? (including /1).
    I'm not sure if that means there is a /N as well as a NCO adder, as both have uses.
    NCO is good for granularity and matching average rates, but it can give jitter for non-binary adder values.
    /N clock control is jitter free.
  • Pictures, or it didn't happen.
    Ok, Ill snap a photo of my old amber screen, signal notes, etc... Monday for you. I will add the notes because they will be more interesting than the video will be. :j
  • cgraceycgracey Posts: 14,303
    edited 2015-10-12 03:10
    jmg wrote: »
    Rayman wrote: »
    I've found you can get good divide-by-N performance for billions of cycles (before an imperfection) with an NCO by using an adder value of maximum/N+1.
    Take 1/3, for example, in a 32-bit NCO. 1/3 = $55555555. If you don't add 1 to it, it won't roll over until the 4th add, then on every 3rd, thereafter. By using $55555556, instead, you get a rollover on every 3rd add, right from the start. Every few billion adds thereafter, you will get a rollover in only two adds, instead of the usual three. This anamoly will rear it's head long after a scan line, or something similar, has finished.
    cgracey wrote: »
    Sounds like you do not have a /N choice from that reply ?
    I can see the earlier disturbance is removed, but the longer-term issue remains...
    Let's consider 120MHz -> 40.000MHz
    120M/(2^32/0x55555556)-40M
    = 0.0186264514923095703125 Hz error (high)
    53.687 s disturbance rate,
    instead of 25.000ns, one period is 16.667ns
    120M/(2^32/0x55555555)-40M = -0.00931322574615478515625 (low)
    107.374 s disturbance rate
    instead of 25.000ns one period is 33.333ns
    A monochrome TV may not notice this, but there are other clocking systems where such a phase disturbance is going to be quite nasty.
    jmg wrote: »
    cgracey wrote: »
    The Transfer NCO's phase can be reset on scanline start using XZERO, as opposed to XCONT, so that any would-be anomaly gathering in the LSB'S can be zero'd out. In practice, those periodic disturbances can be avoided.
  • Looks good on two further monitors PH, a Telefunken and a Sony. Rock Solid
    So do these instructions allow you to set the streamer speed?
    XINIT D/#,S/# transfer init, reset phase
    XZERO D/#,S/# transfer update, wait for rollover, reset phase
    XCONT D/#,S/# transfer update, wait for rollover, continue
    I didn't see them in docs...
    edited 2015-10-12 13:12
    Ok, I searched and found this comment from Chip:
    SETXFRQ is the streamer's freq for its NCO. If the MSB is set, it will cause the streamer to fire every clock. So, it's like FRQA, but with an MSB that allows 100% firing. I need to document that, of course. In the FPGA files I just posted, there's a "sin_cos_dacs.spin" program that uses it to generate sine/cosine waves.
    Ok, I think I understand it now... Looks like there are two different things called "Streamers"... One is to/from HUB and one is from LUT to DACs.
  • Tubular, that is good. I took significant liberties with the vertical sync...
  • Good find! We will do much more on this front when we can coax more outta Chip.
  • Picture: It's not exciting, but here it is anyway...
    3264 x 1836 - 2M
    3264 x 1836 - 2M
  • rjo__rjo__ Posts: 2,114
    I have a monitor, a cable, and the time (of course I can't find the remote). I want to try this, but before I do that... is this still working with Chip's latest revision?
  • It might need a tweak. I'm actually up early thinking about doing just that. Now that my USB is working, I can actually run a program without 5 minutes (literally) of futzing around.
    Being just a test, the code is really simple. Not much in there at present. Not much to change...
  • Here is the modified one using latest addressing syntax.
    crisp and clean on a cheapo RCA
  • Did you run it on a 123?
    yes
    I never thought a square could look so pretty!
  • Bummer. Mine does not output the signal... well, I'll go through the whole setup again and see if something shakes loose.
  • Come on... it's a monochrome square. Lol
  • Runs Ok on both DE2-115 and Prop123-A7.
    A7 output is dimmer than DE2 because of different DAC configs.
    Video output is on DAC2 on A7 board.
    DAC labels on A7 board are a little confusing.
    The schematic refers to DAC0 and DAC1 yet the board overlay refers to DAC's 0 to 5.
    Chip mentioned this will be rectified on A9 board :)
  • Awesome. I did not check DAC 2. Mine probably works fine.
    On the blue channel B(0).
