Anybody have any ideas on a nonvolatile pulse counting totalizer that won't wear itself out? — Parallax Forums
I need to accumulate pulses from a flowmeter and keep my count as incorruptible as is possible, to the point of dedicated hardware.
Some ideas I have considered are dedicated EEPROMs (with a wear-leveling strategy applied), zero-power RAMs, battery-backed RAMs, and even ferromagnetic memories which require no power but are expensive and hard to get. The project is also wireless so off-board integrity management is also possible. I'm going for long-term accuracy so I can say with confidence that the count is accurate.
One strategy I have given some thought to is to write the count to several EEPROMs simultaneously and compare them against each other at read time. If one of the chips is different from the others it is flagged as bad. One problem with EEPROMs is that something could happen between the pulses occurring and them actually being written to the EEPROM.
Mechanical counters are out but could be utilized for additional verification.
I'm not looking for code or anything, just points to ponder. I haven't landed on anything solid yet.
Thanks in advance, bryan
  • What about some sort of super cap to act as a backup power supply. The normal power supply is continuously monitored and if the normal supply goes dead the Propeller writes the value to EEPROM while powered from the super cap.
  • Wonder if there are any Consumer MEMS products out there ... "yet"
    In 1995 I was given a tour to a military testing site where we had a technology exchange program setup with the facility. I will not mention the location, but in the midst of "gadgets" they had an electro-mechanical combination lock. Now that doesn't seem that impressive until I tell you that is was made out of silicon and was incorporated on the die of a chip. Alternatively they also had an incremental 128 bit binary counter that was also mechanical in nature but constructed at the silicon level. ... and yes, completely nonvolatile bi-stable mechanical latches.
    edited 2015-10-09 03:11
    If you want to keep it simple and avoid battery or supercap backup you could either go to FRAM memory (FM24C04 etc) which besides having unlimited (10^14) read/write cycles is also inherently non-volatile. Alternatively you can use the EEPROM a lot more than you think. If you arrange the memory as an array of 16-bit counters for instance that as you fill up one you move on to the next one. That way no counter has been written more than 65,535 times and although it could do much more we keep it simple. Now to read out the count even from power-up we simply advance up the array until we find the latest which is not $FFFF and use that count plus the index<<16 as the count. This is also the way we setup the current counter.
    The funny thing is, if the counter has to be non-volatile then what happens to the counts that are missed when it's powered down? This is where the micro-power battery/cap solution works well, it is always active and basically only needs RAM which is internal to the micro of course. You know that many RTC chips have extra RAM which you could easily use too. The MCP79410 for example has 64 bytes available all nice and safely powered by a battery/cap over I2C.
  • jmgjmg Posts: 15,200
    edited 2015-10-09 03:39
    bte2 wrote: »
    Peter makes a very good point, you really need a backup-counter, not NV memory.
    I think there are RTCs that do exactly that.
    Google find this :
    ["3.1 Event counter mode
    Two real time clocks, PCF8583 and PCF8593, have an extraordinary feature. It is the event counter mode which can be selected by setting the appropriate bits in the control register. In this mode the oscillator is disabled and the oscillator input is switched to a high impedance state. This mode can be used to count pulses applied to the oscillator input OSCI. There is no crystal in the circuit and OSCO is left open circuit. The event counter stores up to 6 digits of data. Events are stored in BCD format. The 6 digits use three 8 bit registers (hundredth of a second, seconds, and minutes). D5 is the most significant and D0 the least significant digit. Every digit can contain values ranging from 0 to 9 and thus up to 999 999 events can be stored."]
  • The device will be in control of the pump so it wouldn't make pulses while the controller was off.
    The reason for the request is that, if I ask it in two years how many pulses it has counted, I have to accept that number without question, even if it was corrupted and therefore meaningless. I have no way to know if the 1,688,242 number that it reports is any good. I also thought about periodically (once an hour or so) write to some sort of ring array so that if anything is amiss at review time it might be obvious.
    All I am attempting to accomplish is to cement my confidence that the number reported is real for all circumstances short of a direct lightning strike. This isn't for just one project, it is actually a circuit I would use in a multitude of devices for a multitude of reasons (such as engine/machine hourmeters and cycle counters).
    Thanks for the replies, you have given me some food for thought :-)
  • Ok, so I also do periodic logging into a circular EEPROM buffer and this is useful for diagnostics too. The array of 16-bit counters works in a similar way to the logging buffer and doesn't require any special hardware assuming you are already using a Prop. Some of these devices just use serial Bluetooth to report so I can easily log in with my phone and also change settings if need be.
    If you want you could also use wider counters to max out the endurance so each counter counts up to a million before moving on to the next counter. Either way EEPROM is already there and the right software method keeps it simple.
  • go to FRAM memory (FM24C04 etc)
    Thank you for that. I stumbled into this which looks very promising:
    http://www.cypress.com/file/41651/download
  • Ok, so based on my previous post... I found some more information on MEMS ... Sandia was experimenting with this in 1995 when I visited the facility and had some pretty cool stuff advanced for even today's standards. Can't imagine what they are playing with now. :-)
    http://www.sandia.gov/mems/_assets/documents/bibliography/3_13MEMS.pdf
    I used to work at Honeywell SSEC repairing wafer fab machines. The stuff in the pdf above made us look like we were building Model Ts :-)
    bte2 wrote: »
    In that case, a simple rolling EEPROM store when the pump was on, would give you a slope of numbers you can then check for fit at any time.
    At low ~hourly write rates, and a modest sized EEPROM that is a lot of time between over-writes.
  • You know that many RTC chips have extra RAM which you could easily use too.
    I made this neat little discovery back when I was building PC-DOS based control systems. I needed a non-volatile production counter and I didn't want to use the hard drive. IIRC, the hard drives back then would "park" the heads after a period of inactivity so after boot-up, I would let that happen and use the spare RTC locations to keep count of parts produced.
  • evanhevanh Posts: 17,272
    MRAM is the only non-volatile RAM. All others have a wear factor or require a battery.
  • You can get pretty good longevity from the upper 32K of regular EEPROM if you're careful. If you're storing a long, that gives you 8K unique locations where you could store a value.
    The EEPROM we use for Propeller programs is good for around 1 million erase cycles. When you go to write, start at the beginning and search for the place where the value was last stored. (You can't just store that in EEPROM, because then that pointer gets worn out.) When you find it, erase it and write the update at the next location, circling around to the beginning. This gives you 8 billion write cycles, which is probably enough for most applications.
