PLL's in Cyclone V and P2 — Parallax Forums
For when a PLL FPGA build is available, the PLL details are going to matter.
There are some code apps where 50MHz is not going to fit.
eg for 48 or 96MHz USB numbers from 50MHz, /5 for 10MHz fPFD and 960MHz VCO covers 96MHz /10 and 48Mhz /20
 --------------   Cyclone V PLL  ---------------
fIN -> /N  -> [PFD] <- /M <- [VCO] -> /C -> SysCLK
/M,/N,/C counter sizes = /1 to /512
fIN Input clock frequency
–C6 speed grade 5 — 670(52) MHz
–C7, –I7 speed grades 5 — 622(52) MHz
–C8, –A7 speed grades 5 — 500(52) MHz
fINPFD Integer input clock frequency to the phase frequency detector (PFD) — 5 — 325 MHz
fFINPFD Fractional input clock frequency to the PFD — 50 — 160 MHz
fVCO PLL voltage-controlled oscillator (VCO) operating range
–C6, –C7, –I7 speed grades 600 — 1600 MHz
–C8, –A7 speed grades 600 — 1300 MHz
P2 PLL
fINPFD phase frequency detector range (PFD) = ?
fVCO PLL (VCO) operating range = ?
Comments; The CV has a relatively high fPFD minimum, but also has a higher VCO
The P2 will likely have a lower fPFD lower limit, and also a lower VCO.
  • evanhevanh Posts: 17,203
    Is this topic leading anywhere?
  • jmgjmg Posts: 15,200
    evanh wrote: »
    Until a PLL FPGA build is available, I would expect it to be quiet :)
    ( I just had the DOC's opens from comments in another thread )
