Pe com
in Propeller 1
I get com established but the pe board
And computer won'tcommunicate. Serially they communicate. Identify hardware won't establish. I get a com number but they don't establish a link.
What do I need to do? Littledrizzle
Could you give the full name or Parallax part number for the PE board you are having issues with?
And also your computer operating system.
That will help us to help you!
Computer oper. Sys. Is windows 8
The Propeller needs 3.3 volts on both it's VDD inputs, (not just one). Also VDD needs to go to ground on both pins on the Propeller.
If you are only getting 2.5 volts, there is something wrong with the 3.3 volt regulator circuit. I would dismantle the 5 and 3.3 volt regulator circuits, and then re assemble them paying close attention to the part numbers and values of components.
How are you powering the breadboard? 9volt battery or wall power supply?
I will disassemble the supply and reassemble it.
9 volt batteries are notorious for being the problem with these circuits. The cheap ones will not provide enough voltage to run the whole PE system for more than 1 hour.
Get one or two brand name batteries and try again.
Also read:
https://www.parallax.com/sites/default/files/downloads/32305-PEKit-40-PinDIP-Enhancements-v1.0.pdf
