Simple Quaternion Library?
![michaellangford99](https://forums.parallax.com/uploads/userpics/527/nZNNLDJGQF87Y.jpg)
in Propeller 1
Hello,
I was wondering if anyone knows of a Quaternion library for use in an IMU, or how to make one. In my current setup, my gyro will lose 90 degrees if I tilt it 90 in pitch, then roll it 90, and then put it back down, because it is just integrating the rate. This would not happen if a Quaternion was used. Even though I am Kalman filtering my gyro and accelerometer, I will still get some data loss for a few iterations. I am making a quadcopter, and though the rotations described would probably never happen, anything remotely like it could severely mess the flight up.
https://github.com/ZiCog/madgwick.js
Includes Madgwick's and Mahony's AHRS accel, gyro and compass fusion code in C and Javascript.
From my limited experiments it works quite well with out the compass inputs.
The C could be usable on the Prop as is, if it fits. Else you will have to port that to Spin.
Didn't someone already do this in Spin ?
It's not a quaternion, but it's easy enough to get the angles out using ArcSin.
http://forums.parallax.com/discussion/131022/propeller-dcm-now-with-source/p1
And there's also: https://github.com/parallaxinc/Flight-Controller
It uses a quaternion for the updates, then converts to a matrix to do the drift compensation. It's still in development, but it's flyable now. I'm hoping since it's open source, no one will mind me posting it early.
https://github.com/srlm-io/anzhelka/blob/master/software/spin/src/block_moment.spin
Resulted in:
This could then be run in a special version of F32 that would chug though the math instruction at full assembly speed. In my testing I found that much of the slowness of F32 was the Spin overhead, and so if you can put your math operations back to back things get alot faster.
https://github.com/srlm-io/anzhelka/blob/master/software/spin/lib/F32_CMD.spin
I don't really suggest that you use the code as is, but maybe it will provide some inspiration. Also in that repo is a pretty handy doc walking through the implementation of a quadrotor control system.
https://github.com/srlm-io/anzhelka/raw/master/doc/reports/quadrotor_mathematics.pdf
maybe this is helpfull
Reinhard
