Removing old/hidden COM ports in Windows
Seairth
in Propeller 2
I'm just putting this in a separate post so it doesn't get buried as a comment elsewhere.
To remove old/hideen COM port assignments for the FTDI USB Serial ports, you will need to perform the following steps:
For step-by-step instruction on doing this, read this page.
- Add a system environment variable "devmgr_show_nonpresent_devices=1".
- Open Device Manager.
- In the menu, enable "View > Show Hidden Devices".
- Under "Ports (COM & LPT)", all of the FTDI COM ports will be labeled "USB Serial Port". Remove at will!
I guess each badge had a new COM Port?
I got over the nasty Flu that prevented me from helping. Would have love to be there.
set devmgr_show_nonpresent_devices=1
start devmgmt.msc
Then I just right-click the batch file and, you guessed it, run as administrator. [8^) Then I just follow your steps 3 & 4.
Jonathan
Hah! Indeed I did! I'm sorry you weren't able to make it. I was looking forward to meeting you. Maybe next time.
