Propeller activity board voltage
Zap-o
in Propeller 1
I just received my propeller activity board and know the pcb states 6-9 Volts, however; I have limited resources and looking over the schematic I see no reason why I could not supply up to 20 Volts. Could someone point out an issue if any before I supply 13.2 Volts to the Propeller activity board.
Always thanks in advance.
So yes, you can run the Activity Board off 13.2V, but you will be limited in what you can do with it due to heat. I have some old power cubes with voltages from 6 to 9V and current ratings from 600mA to 1A that I keep for this sort of use. People throw them out all the time. Check garage sales too.
Awesome - thanks for that tip. I forgot about the "heat" detail. Ill look into gluing a heatsink on to it and a fan if needed. Otherwise sounds great. Again thanks.
I once again went over the schematic and found no reason 13.2V would not work so with Mike Green in mind I went ahead.
The Activity board woks perfectly and the voltage regulator never appeared hot to the touch. I have a heat sink ready to glue on said IC, but have not needed it yet.
I am operating 2 servos and as many cogs as one imagines in a day programming the Activity board, sounds etc. nothing abnormal accrued.
Thats a good point I am using the servos at 13.2V for now as this is just a proof of concept design I am having fun with. I have the real servos still in a box and they will run from a PCB I design after this all works out. I did run the servos on 5V but I was afraid the load would be excessive as the voltage regulator reset the code a few times.
A 13.2V supply will definitely cause arcing ... thus pitting of the brushes. Use some kind of external regulator to reduce the voltage to the servos.
