Two general classes of IC sockets, which is better?
I need to buy some IC sockets for a new project, and I intend to buy much more than I need to have an inventory on hand. There appear to be two general classes of IC sockets and I'm curious if there's an advantage to one versus the other.
Pin header style: http://www.digikey.com/product-detail/en/SA143000/ED3014-ND/3313545
Pressure fit on pin: http://www.digikey.com/product-detail/en/A14-LCG-T-R/AE9990-ND/821744
They're the same price, so is this an issue of preference, or is there some benefit to one style over the other?
Ditto. Machined pins are better and usually more expensive. Besides, wouldn't you prefer to buy On Shore vs. Assmann?
BTW, if you need any 8 pin sockets (or a quick method to test lots of any sockets), I got you covered.
@Erco, that is a riot.
From one hoarder to another, I humbly say "stock up, dude"!
Contact Resistance: 4miliohm vs 30miliohms
Current Rating: 3 amps vs 1 amp
Insertion Force: <250g vs not listed, but maybe 100g
Removal Force: >50g vs not listed, but maybe 35g
NOT when I've been buying them.
The dual-wipe ones are under 1c/pin, much cheaper than the turned pin ones.
try for example
http://www.digikey.com/product-detail/en/ED14DT/ED3045-5-ND
Irrespective of the foregoing, however, I quit using any IC sockets years ago, in favor of just soldering the parts in.
Yes, sockets are a tail-end technology.
We have one legacy product using PLCC44 sockets and we changed to the HPT types from AMP/TE to give the customer more reliability.
Those sockets got more costly and harder to find, so we had to redesign the PCB for direct mount soldering.
sale on machined pin 16 pin sockets, 20/ $2.50
