Arlo help - wiring diagram for quadraencoders using activitybot controller
I'm building an Arlo, using the Parallax components (HB25's, Arlo Power Distribution, Aluminum wheel kit. But I need help understanding how to connect the servo and encorder leads to my Activitibot board.
Ant help is appreciated as I'm somewhat frustrated.
Thank you,
Alan
Thanks for the thread. I am using c but I've not been able to get the arlocalibration tool to compile. I get an error on the first line of the file.
Any thoughts?
Thank you,
Alan
Any thoughts?
If you use C then you'll want to follow this guide.
http://forums.parallax.com/discussion/152636/run-activitybot-c-code-in-the-arlo/p1
Here's an article related to using AB code with the Arlo hardware.
https://www.parallax.com/news/2013-12-23/run-activitybot-c-code-arlo
If you want to use Spin, you can use the modified Eddie firmware available from my GitHub.
You'll want to download the archive "EddieActivityBoard - Archive [Date 2015.01.01 Time 20.21].zip".
The pin assignments are listed in the header file.
If you use the Eddie firmware, I'll try to help you with any questions.
Thanks again for your help on this.
Alan
This post was the number one most helpful for me as far as wiring:
http://forums.parallax.com/discussion/comment/1234335#Comment_1234335
This thread also has some good info on getting the Arlo code working:
Here is my blog article about getting it going,
http://ekpyroticfrood.net/?p=165
but it doesn't have much on wiring.
