Using the propeller to program other microcontrollers
Hi all
Will the Propeller plug program the Arduino Pro Mini 328 microcontroller 3.3V 8MHZ ATmega 328 Processor.
Allie
Allie
Then once you get the Picaxe programming the original Propeller, you close the circle and have an Over Unity loop, which will either generate endless power or a black hole.
Do NOT cross the streams.
