I'm trying to find Bamse's original tutorial on NTSC/PAL generation (not the multi-cog tutorial). All I have found are links to it and the migration to the new forum has broken all the links.
That's not the forum migration that is the demise of the wikispaces account. I believe there was talk of people migrating that stuff elsewhere. Sorry no idea where.
Yes Publison that's the one! Thanks. Heater I found that all the links are broken on the Hydra Master List. I wonder if most of the posted links that were made be before the change are now broken. If so is there an easy conversion to make the links correct?
Edit: You may find a back up/mirror copy of the wikispaces in this thread: http://forums.parallax.com/discussion/158184/propeller-wikispaces-com-deleted-restored/p1
http://forums.parallax.com/discussion/104737/50-line-graphics-driver
Someone has some work to do....
http://forums.parallax.com/discussion/108626/hydra-projects-master-list
Unfortunately, all the links need to be searched individually, from what I can see, such as 3D Moster Maze:
Search Google for "3D Moster maze forums.parallax.com"
