TSL235R Object
in Propeller 1
I figured I'd post this as I saw a few posts of people commenting on the lack of an object for it. I modified the files in the OBEX for the TSL230_pi, weeded out everything that appeared to be unnecessary for this chip and ended up with something that works well enough for the purpose I needed it for. I'm not sure if everything is 100% accurate but it all appears to work correctly in my setup, hopefully someone else may have some use for it also.
Enjoy!
The attached file is a modification of the tsl230_pi_demo found in the OBEX at http://obex.parallax.com/object/614
I did not create this, only modified it to work with the TSL235R, due credit belongs to the original author(s).
Enjoy!
zip
12K
Thanks for posting, I need to try it out.
Also thanks to BR and Paul Baker for the original coding.
