Data Logging Options for the Propeller — Parallax Forums
Duane DegnDuane Degn Posts: 10,588
edited 2015-08-19 22:28 in Propeller 1
I generally use a SD card when I want to log data with the Propeller but I'm currently working on a project which needs higher reliability than what I think SD cards provide.
Every so often when I use a SD card for data logging the card becomes corrupt and I end up needing to reformat the card in order to use it with the Propeller again. This doesn't happen often but it happens frequently enough to be a concern for this current project.
I was just looking over the Propeller Memory Card specs and I think the card's Winbond W25Q32FV chip looks like a good option for data logging. If I'm reading the specs correctly the chip retains its memory between power cycles. I think 4 Megabytes is probably enough memory but I'm not sure yet.
Do you guys have favorite memory chips? Any suggestions?
I should say I generally use Kye's SD driver. I'm pretty sure Kye's driver is picky about any sort of corruption on the SD card. I'm I ruling out SD cards too quickly? Can they be used reliably without any need to remove the cards?
    edited 2015-08-19 22:38
    Duane,
    My no brainer has been the Memory Stick Datalogger but it may not be in your budget or in you space constraints.
    No problem up to 2 GB.
  • I know there are several of you who like these things but I personally have had a lot of bad experiences with them. I've had a really hard time finding USB drives to work it.
    Besides, you are correct, it would be way too expensive. I'm looking for memory to into a board to be produced on a relatively large scale (at least compared with my many hobby projects).
  • Yeah, I figured you had a bigger project in mind :-)
    SD cards are notoriously un-reliable. Not worth thinking about.
    We ran many industrial systems from Compact Flash cards for ages and I don't recall them ever failing. But that is a big interfacing problem. Can you even still get them ?
    Winbond sounds like it's worth investigating. You can always use more than one for further capacity.
    edited 2015-08-20 01:37
    I have had extensive experience using SD cards and the biggest problem I see for datalogging is being forced to use the FAT file system because you need some PC to read it. If you think about it you can see you are continually writing to the directory with file size updates and the other area that gets hit is the FAT itself.
    What I do is preformat the card with fixed files (8.3 names) and fixed sizes filled with zeros and in the process there is no fragmentation either and this I also rely on too. Now I encode all data as text with a null terminatation so I don't update any file sizes either, only the current sector may be rewritten several times before it moves onto the next. This simplifies the runtime operation of the datalogger and on power-up it just needs to scan through to find the latest file and a quick binary search to find the end-of-file termination.
    Now it's just a question of what happens to this when you try to read the files on a PC as it won't complain about the formatting since it hasn't been touched. Text files that aren't full will say 1MB file size but might only have 100k in data but that is very easy to work around and is in fact viewable on most editors. Of course you could have an eject option on your datalogger which updates the file size etc.
    Some of these dataloggers are accessed via FTP in which case I just report back the data file size rather than the FAT file size, no problem.
    Alternatively since you are considering serial Flash you obviously are not worried about FAT so you can do exactly the same with SD, just treat it as one big memory, which is in fact how my EASYFILE system references it, either the whole card as up to 4GB or each file up to 4GB.
    edited 2015-08-20 02:35
    Heater. wrote: »
    Normally I'd agree but Peter makes it sound like it's possible to use SD cards reliably.
    Heater. wrote: »
    I have a couple CF cards. I doubt this is a practical option nowadays.
    Heater. wrote: »
    I've been looking at some of the memory chips available and I'm a bit overwhelmed by the options.
    This sure sounds interesting. I don't think I really mind keeping track of where all the data is located. I doubt we'll use SD cards in this project but I want to try your method sometime.
    Now it's just a question of what happens to this when you try to read the files on a PC. . .
    I don't think we would want to have a slot for SD card access. I think all the data will be retrieved with a USB connection (now without resetting the Prop), over a RS-485 Modbus connection or over Bluetooth.
    Some of these dataloggers are accessed via FTP. . .
    Does FTP imply a ethernet connection?
    I'll need to research FTP to see if it has advantages I can use with our present communication protocols.
    Alternatively since you are considering serial Flash . . . you can do exactly the same with SD, just treat it as one big memory, which is in fact how my EASYFILE system references it. . .
    I'll need to try your EASYFILE system sometime. I think I have other projects where it would be useful.
    edited 2015-08-20 03:05
    Word of caution here, if you want to take advantage of any of my software you will have to learn Forth!!! The danger is not learning, perhaps it's the "relearning", but more so it is because Forth changes your mindset on "programming" and like a lot of fun things it is also very addictive, addictive, addictive..
    Anyway the main point is that SD cards are just Flash like any other Flash but accessed with the SD SPI protocol. There are some things under the hood to do with wear levelling etc but nothing that affects the access methods.
    I use FTP for dataloggers using WIZnet chips such as the W5200 and W5500 or even the older W5100 as used on the old Spinneret. In fact if you click on the FTP link in my sig from your browser you should be able to connect to a Prop running EASYFILE and EASYNET software. You can even Telnet in on port 10001 and talk to to the system and even type an "ls -l" to list the files and details etc.
    So if you only ever have an internal memory you don't ever have to worry about FAT compatibility, but it sure does help initially in getting files onto it in the first place if you need to. The EASYFILE software takes the pain out of it and in fact once you open a file you can access it as if it were virtual memory without having to be concerned about any file system stuff.
    If your files are large you will find the FTP connection the fastest for transferring them but I have also accessed them over RS485 and Bluetooth as well. What I need to do next is interface one of the ESP8266 modules and get it working with FTP.
    My IoT5500 +P8 Ethernet module, the size of a magjack incorporates a Prop and microSD (or Flash) and is all setup for datalogging.
    Here's a local Telnet session to this unit although it is still running an older version of the software (I need to update it).
    peter@peter-L702X-LM17 ~ $ telnet 192.168.16.150 10001
    Trying 192.168.16.150...
    Connected to 192.168.16.150.
    Escape character is '^]'.
    WELCOME TO THE IoT5500 TELNET SESSION
    Use Forth commands, for help type QWORDS
    Try ls or DIR for directory
    Session time is unlimited but all other network ports
    will be blocked until Telnet is disconnected
      ok
    ls
    WIDGET
    MENU    .TXT   MENU1   .TXT   EASYNET .AVI   FIRMWARE.ROM   EASYNET3.AVI
    LOVE    .WAV   EXTEND  .FTH   P8      .H     EASYNET .FTH   W5500   .FTH
    128K    .BIN   256K    .BIN   W5200   .FTH   WELCOME .TEL   WELCOME .FTP
    FSRSCH  .PNG   FSRPCB  .PNG   IMAGE          HTTP404 .HTM   IMAGE2
    IMAGE1         LOGON   .HTM   TACHYON .HTM   SITE0004.LOG   SITE0003.LOG
    CHARLCD .JPG   ECOLCD  .PDF   LOVE    .MP3   MENU2   .FTH     ok
    FOPEN WELCOME.TEL
    ...opened at 0003.D02A   ok
    FILE@ $100 SD DUMP
    07A0_5400:   57 45 4C 43  4F 4D 45 20   54 4F 20 54  48 45 20 49   WELCOME TO THE I
    07A0_5410:   6F 54 35 35  30 30 20 54   45 4C 4E 45  54 20 53 45   oT5500 TELNET SE
    07A0_5420:   53 53 49 4F  4E 0D 0A 55   73 65 20 46  6F 72 74 68   SSION..Use Forth
    07A0_5430:   20 63 6F 6D  6D 61 6E 64   73 2C 20 66  6F 72 20 68    commands, for h
    07A0_5440:   65 6C 70 20  74 79 70 65   20 51 57 4F  52 44 53 0D   elp type QWORDS.
    07A0_5450:   0A 54 72 79  20 6C 73 20   6F 72 20 44  49 52 20 66   .Try ls or DIR f
    07A0_5460:   6F 72 20 64  69 72 65 63   74 6F 72 79  0D 0A 53 65   or directory..Se
    07A0_5470:   73 73 69 6F  6E 20 74 69   6D 65 20 69  73 20 75 6E   ssion time is un
    07A0_5480:   6C 69 6D 69  74 65 64 20   62 75 74 20  61 6C 6C 20   limited but all
    07A0_5490:   6F 74 68 65  72 20 6E 65   74 77 6F 72  6B 20 70 6F   other network po
    07A0_54A0:   72 74 73 0D  0A 77 69 6C   6C 20 62 65  20 62 6C 6F   rts..will be blo
    07A0_54B0:   63 6B 65 64  20 75 6E 74   69 6C 20 54  65 6C 6E 65   cked until Telne
    07A0_54C0:   74 20 69 73  20 64 69 73   63 6F 6E 6E  65 63 74 65   t is disconnecte
    07A0_54D0:   64 0D 0A 00  00 00 00 00   00 00 00 00  00 00 00 00   d...............
    07A0_54E0:   00 00 00 00  00 00 00 00   00 00 00 00  00 00 00 00   ................
    07A0_54F0:   00 00 00 00  00 00 00 00   00 00 00 00  00 00 00 00   ................ ok
  • How about this?
    https://www.sparkfun.com/products/9530
    If your data rate isn't too high, you can simply use FDS to interact with it.
  • What's the sample rate of the sensors?
    IoT is great for adding tons of reliable storage to a data stream.
  • I feel that the problems with SD cards are much much more likely to occur during the hardware and firmware development process than they are once all that has settled down. I recall a lot of problems with a batch of micro-SD cards as a product was rolled out, but now a couple of versions later it has a full size SD and it is always specified SanDisk. It is a long time since I've heard of an SD card problem with that system. If you are paranoid, you can spring for an industrial SLC card instead of the garden variety MLC.
    On my BASIC Stamp OWL platform I used the Atmel AT45DB081 serial dataflash chip (1Mbyte per 8-pin soic). It was very reliable. That IP is now in the hands of Adesto Technologies. Interesting product line. Not sure, but I think it works in a manner similar to the Winbond chips.
    In a current project, I'm using eeprom, the AT24CM01 (128kByte) for both the boot 32k and 96k for logging. I had to convince the customer that it will be advantageous to limit the memory requirements. Let the Prop pre-process and compress the data into that smaller memory. One issue is how long it takes to offload data via USB via a serial bridge (FTDI).
    The world is awash in too much data!
    edited 2015-08-20 15:09
    Seairth wrote: »
    How about this?
    Don't you think that would be kind of insulting to the Prop? The Prop can certainly handle logging the data to the SD card directly. And at $25 a pop I have a feeling you didn't read the whole thread (something I'm often guilty of). $25 is much more than we would want to pay.
    xanadu wrote: »
    I believe the sensor can sample in the kilohertz range but I doubt we'll need to sample more than 10Hz. I think 80 bytes per second will be the close to the maximum amount of data we'll want to store.
    xanadu wrote: »
    I'm not sure what you mean by this. Does this assume a constant connection to some cloud storage? Is this done over WiFi? We've wondered about adding WiFi but I doubt that's going to happen. Bluetooth seems to work fine. We're wondering about having a smartphone collect the data via BT and then having the smartphone email the data. I suppose if we had WiFi on the sensor itself, we could have the sensor send the email directly.
  • In a current project, I'm using eeprom, the AT24CM01 (128kByte) for both the boot 32k and 96k for logging.
    It would be nice if we could do this too but I think 96k is just too little memory. I think we want a megabyte or two.
    I don't think we want the deal with SD cards. There won't be a slot in the enclosure so the cards won't be accessible to the end user. Besides, I'm pretty sure the memory chip will use less board space which is an added bonus. I think for a few megabytes, a memory chip will probably cost less than adding SD card hardware and purchasing reliable cards (though I don't know enough about this to be sure).
  • Is the SD card hardware not reliable enough for you, or is it simply the FAT filesystem?
    On top of Peter's EASYFILESYSTEM in Forth, PropWare in C++ gives you direct access to the SD card for easy read/write of blocks as well.
  • Duane Degn wrote: »
    I don't see a problem with using other MCUs along with the Propeller. Just because the Propeller can do something, doesn't mean that it's the best choice for the job. If the Propeller was that easy to use with SD, this thread wouldn't exist in the first place.
    Duane Degn wrote: »
    True, it is cost prohibitive (I did see your comment about the USB logger). I was more thinking along the lines of using the schematic to implement your own variant.
    But, to your other point, I did somehow get caught up on the wrong part of your post. I focused on the SD card issue, not the part where you were saying that a dedicated IC would be good enough. The advantage of using the referenced winbond part is that there is already code for it. It looks like you could get a 16MB drop-in replacement for less that $2 each (actually, up to 64MB, but 16MB was the largest digikey sold in unit quantities).
  • Seairth wrote: »
    Duane Degn wrote: »
    Do you have a part number for that? There are so many memory chips on Digikey I had a hard time figuring out which chip did what.
    I've only used SD cards with the FAT filesystem.
    I'll take a look at your driver for other projects but I doubt we'll use a SD card for this project.
    Am I correct to assume if all we need is a few megabytes of storage, an SD card would be overkill?
  • SeairthSeairth Posts: 2,474
    edited 2015-08-20 16:50
    Duane Degn wrote: »
    Seairth wrote: »
    do a search for W25Q128 (or W25Qxxx, where xxx is the number of desired megabits).
  • Seairth wrote: »
    That did it.
    Thanks.
  • xanadu wrote: »
    xanadu wrote: »
    [/quote]
    I'm sure that the ESP8266module can do this, but you wouldn't be able to use the free online IoT sites like Thingspeak, they use 15 second intervals.
    If it is feasible to use a smartphone, Android will take care of this. I'm not sure about sending the emails with data, that might require some custom software.
    Here's a PDF on the Winbond chips.
  • Tracy AllenTracy Allen Posts: 6,664
    edited 2015-08-20 18:40
    One reason I liked the Atmel (Adesto) dataflash is that it has dual RAM buffers on-chip that stand between the SPI and the flash pages. The RAM buffers can also be used for general purpose storage--a great asset for the memory-starved BASIC Stamp! Not a big deal for the Prop. For 8Mbytes the Adesto 45DB641E costs $3, versus $1 for the Winbond W25Q64. Of course, there's Mike's great Femto code for the Winbond.
    As for SD cards, we're talking orders of magnitude larger capacity and built-in wear leveling. I have them often in boxes with no external access slot, and the socket real estate can often be found on the bottom side of the PCB where it doesn't seem so intrusive. I use a modified version of FSRW.
    Glad to hear it. As always, do let me know if you have questions.
    Duane Degn wrote: »
    What's your definition of overkill? I'll check tonight, but the code size required to interface with an SD card shouldn't be very large. Most of the logic normally associated with SD cards come from the filesystem, not the physical storage device. This is all bogus until I can put some numbers to it though, so bear with me until I run some tests this evening.
  • I fought for an hour with SimpleIDE trying to get this to compile there so I could use its binary size utility but never got it to work. So, the following numbers come from propeller-load instead
    Program 1, with SD routines
    #include <PropWare/filesystem/sd.h>
    #include <simpletools.h>
    int main () {
        PropWare::ErrorCode err;
        uint8_t             buffer[PropWare::SD::SECTOR_SIZE];
        PropWare::SD sd(PropWare::SPI::get_instance());
        err = sd.start();
        if (err) {
            putStr("Error occurred during startup: ");
            putDec(err);
            putChar('\n');
            return err;
        const unsigned int addressOffset  = 1024 * 1024;
        unsigned int       currentAddress = 0;
        while (1) {
            err = sd.read_data_block(currentAddress, buffer);
            if (err) {
                printi("Error during read of address %d: %u\n", currentAddress, err);
                return err;
            err = sd.write_data_block(currentAddress + addressOffset, buffer);
            if (err) {
                printi("Error during write of address %d: %u\n", currentAddress, err);
                return err;
            ++currentAddress;
        return 0;
    And Program 2, without SD routines
    int main () {
        PropWare::ErrorCode err = CNT;
        if (err) {
            putDec(err);
            putChar('\n');
            return err;
        while (1) {
            err = CNT;
            if (err) {
                return err;
            err = CNT;
            if (err) {
                return err;
            ++currentAddress;
        return 0;
    And the results:
    Memory Model | Program 1 | Program 2 | Difference
    cmm          |   8,620   |  4,160    |  4,460
    lmm          |  13,136   |  5,584    |  7,552
  • And the results:
    Thanks for the comparison. I know I'll need to start using C more at some point but my current project is in Spin PASM.
    It sure would be nice to have an easy way of reading code from external memory.
    I can read in PASM "cogjects" from upper EEPROM but this is a really awkward way of creating large programs.
    I think C has a lot to offer but I'm really pleased with what I can do with Spin/PASM and it's hard for me to want to go back to not knowing what I'm doing by programming in C. Though I suppose periodically not knowing what one is doing is a good way to keep life interesting.
    koehler wrote: »
    Hard to beat $0.43/ea
    Those are tempting for my own projects but there are so many counterfeit chips on ebay, I don't think I'd trust them in a project I'm doing for someone else. Thanks for the link.
  • TubularTubular Posts: 4,706
    edited 2015-08-22 23:24
    Hi Duane
    I don't know whether this is applicable for your project, but you can also put an SPI memory chip into MicroSD form, which gives you a choice into the future for being able to plug in larger memories/other memory technologies
    http://forums.parallax.com/discussion/144082/microsd-party-board-spi-widgets-for-microsd-enabled-prop-boards
  • I tend to have both on the board as of course you share the lines and use one or the other or have an extra chip select. Even my +P8 board has both and the microSD is in one of those low profile header sockets.
    As for the Tachyon memory model it still has plenty of memory left over even with FAT32 and datalogging handling up to 4 open files. It is only when I implement WIZnet drivers and Ethernet server protocols that I use part of the upper half of the 64k EEPROM for dictionary storage so that all code fits nicely in RAM, no other tricks although SD can be used in for the dictionary in place of the EEPROM if need be.
    The nice thing about developing in Tachyon is that you can develop and test interactively and even while the datalogger is running you can access the files and buffers to see what is going on, even inject data etc. This also applies once the system is deployed and being able to Telnet in is a bonus, even add new functionality to it via the network.
  • Tubular wrote: »
    Thanks for the reminder about those cool gizmos. I doubt we'll be putting a uSD socket on this board but I'll remember those cool tricks for future projects.
    You're going to get me to try this sometime. I've never used Forth but I loved my old RPN calculator and I hear the thought process of using Forth is similar to RPN.
    You'll need to forgive me if I don't suggest a switch to Forth for this project. :smile:
  • MJBMJB Posts: 1,235
    Duane Degn wrote: »
    the only one you need to forgive is yourself
    if you do not try Tachyon soon ;-)
    and yes - having used a RPN calculator helps
    edited 2015-08-23 19:48
    Here in Australia we drive on the left side of the road but in the U.S you drive on the "wrong" side of the road :) Is that right?
    It's funny how people look at the Forth stack as being "reverse" when in fact the common method is the reverse from the Forth point of view. I mean if we parse the infix notation 12 + then we have to ask "what's next?" and proces this and then find out what to do with the result? In Forth there is never this problem as + does not have to compile anything, it just adds two numbers that are processed and sitting there ready on the stack. A conventional compiler has to perform mutiple passes of the source code to "make sense of it" and break it down into efficient runtime code. In Forth the source does not need to be broken down, it is already in its most efficient form ready to run much like PASM. A benefit of this is that you know what is actually happening rather than scratching your head only to find out that the compiler needs whitespace or the braces in the right places ;)
    To me the stack is very natural for programming as I find passing parameters on the stack easier although I don't prefer RPN calculators. It is awkward though to manipulate parameters by position which is also why I minimise the number of parameters passed and refuse to implement PICK and ROLL or stick to "tradition" when it isn't practical.
    Anyway it would be remiss of me to not mention the use of Forth or more importantly Tachyon for this project as all the pieces are in place and have been put together and work. No need to try and make it fit and work and I've successfully used SD cards and Forth for datalogging in commercial volumes for many years.
    I'm a hands-on guy and I love that the code is alive, that I can interact with it on the target in-situ rather than being tied to the PC compiler tools and dealing with the project in an abstract and almost bureaucratic way.
    Yes, as MJB says, the only one you need to forgive is yourself :)
    definition of RPN or reverse polish notation from Wikipedia
    Wikipedia wrote:
    Polish notation, also known as Polish prefix notation or simply prefix notation, is a form of notation for logic, arithmetic, and algebra. Its distinguishing feature is that it places operators to the left of their operands. If the arity of the operators is fixed, the result is a syntax lacking parentheses or other brackets that can still be parsed without ambiguity. The Polish logician Jan Łukasiewicz invented this notation in 1924 in order to simplify sentential logic.
    The term Polish notation is sometimes taken (as the opposite of infix notation) to also include Polish postfix notation, or reverse Polish notation, in which the operator is placed after the operands.[1]
    When Polish notation is used as a syntax for mathematical expressions by programming language interpreters, it is readily parsed into abstract syntax trees and can, in fact, define a one-to-one representation for the same. Because of this, Lisp (see below) and related programming languages define their entire syntax in terms of prefix notation (and others use postfix notation).
    Here is a quotation from a paper by Jan Łukasiewicz, Remarks on Nicod's Axiom and on "Generalizing Deduction", page 180.
    I came upon the idea of a parenthesis-free notation in 1924. I used that notation for the first time in my article Łukasiewicz(1), p. 610, footnote.
    so it is not really related to stack use in Forth.
