DIY DTMF Encoder/Generator
in Propeller 1
Hi all,
Our latest project involved an old school rotary phone! We've been working lately on a series of telephone projects and the first one just happens to be a DTMF Encoder/Generator.
The mcu of choice of course is a Propeller and we, at some point last year, made a custom tiny board for another project. Decided to use it for this one instead. You may of course use any board with a Propeller, and as long as you have the right components connected, you're good to go!
Schematic and code can be found:
http://tymkrs.com/code/dtmf.zip
Or if you'd rather not download a zip file/would like to browse the code first, here're pastebin versions of the Object and the main code:
Object: http://pastebin.com/tGjmzWvP
Main Code: http://pastebin.com/4U93hGs2
And for the sounds that we make: https://soundcloud.com/tymkrs/dtmf-mf-acts-st-kp-kp2-redbox-bluebox
I come here this morning and *poof* there it is
Works great on the demoboard (with pin change, of course). I definitely advise against headphones that don't have a volume control that you can turn waaay down if it's 6am and you aren't quite awake yet, though, otherwise you might have a spaz moment in your chair as the DTMF goes straight to your brain, hahaha
Thanks guys!!
Cheers,
Jesse
At some point, you may need to put an oscilloscope on your output and see what the speaker is seeing. It may be too noisy to work without getting into experimenting with analog filter designs.
Loopy - we had it working well enough to have it call a house phone
