Old School Question - Analog Multi-meter — Parallax Forums
I want to pick up an Analog Multi-meter. I want a good one and probably a new one but I am not opposed to a good used one if I know what I am getting. Any suggestions from those old enough (or crazy enough) to know?
I know that Simpsons and Tripletts are pretty much top of the line - but how much is reasonable to pay - and is this way too much meter?
  • jmgjmg Posts: 15,200
    Wow, who buys analog meters anymore ? ;)
    IIRC the figiure of merit was k Ohms/Volt, so a 50uA meter movement with no active-help, gives 20k Ohms/volt.
    E-bay shows some 50k Ohm/volt meaning either 20uA meters or some active help.
    eBay has plenty of Triplett brands & even some AVO's too...
  • Hi
    I have an old, seldom used analog multimeter I purchased from Radio Shack in the 70's
    From time to time, I pull it out to check trending on analog circuits I'm building.
    My digital multimeter is also not of current design.
    Sometimes what I'm trying to see on the digital meter does not match with changes quick enough to
    see if there is actually something going on that I want to see.
    My guess is that a current design digital multimeter, with possibly some type of anilog display
    will outperform any multimeter that was designed and manufactured in the 1970's
    BUT
    I will still keep and use my old tools until they no longer satisfy my needs.
    I think you would be better off purchasing a new modern multimeter.
    Just my 2cents worth.
    gg
    edited 2015-08-10 07:19
    An analog meter is a wonderful thing. Especially when you can't find a replacement battery your digital meter! Won't work for ohms without a battery of course but if you have a source of volts you figure out how to measure resistance with it.
    Being a Brit I always lusted after an AVO Meter. They are bit on the big and heavy side though.
    Now you got wondering what is the motivation for this hybrid meter:
    http://www.ebay.com/itm/Tekpower-TP7310-Analog-Digital-AC-DC-Volt-Multimeter-with-Resistance-and-Temp-/161577123280?hash=item259ebf3dd0 ?
    A weird enough idea I might need to get one.
  • TorTor Posts: 2,010
    I bought a Japanese Kyoritsu FET VOM analog multimeter back in school (in the seventies) - we got a special offer on the instrument they used at the school. I still have it, it works as well as when it was new. 10 MOhm input impedance (unlike the older analog instruments the school used before). It's as accurate as any of my digital multimeters, the analog display is beautiful. The only reason I'm not using it all the time is simply because of its size - it's pretty big.
  • WhitWhit Posts: 4,194
    edited 2015-08-10 15:22
    Thanks folks!
    To answer jmg's question - I guess the answer is a nut. I have a very good Fluke DMM, a good Extech DMM and some cheap DMMs. I just want to play around with a an old school analog meter. I know I can pick up an inexpensive <$20 model to play with, but I sort want an big clunky old school unit. I don't want something that is junk though - meaning worn out or broken. If I am going to get one - I want it to work as it is supposed to. The dream - brand new - would be http://www.amazon.com/Simpson-260-8-Analog-VOM-Meter/dp/B002R6MWL0/ref=pd_sim_sbs_147_1?ie=UTF8&refRID=1CP09DEXK6B2V6HA957T
    I also like the idea (at least) of a new - still big - modern analog meter - they are not expensive and are made to be tough. Something like this one - http://www.amazon.com/gp/product/B00MI6T0IW?refRID=Q5G3TRGH5B61EDCPTH8B&ref_=pd_ybh_l_1 or maybe http://www.amazon.com/Tekpower-TP7050-7-Function-20-Range-Multimeter/dp/B007IEFC8G/ref=dp_ob_title_def
    I am not sure any of the newer models will get at "just wanting" something like the Simpson or Triplett (or even OLD Japenese Analog Meters). NONE of this is about practicality - It is about feel.
    Like I said - think nut, crazy person, odd duck, etc...
    Crazy hey? OK, you really need an AVOMETER 8 Mk 5, big, clunky, accurate, beautiful, lot's of "feel".
    http://www.ebay.com/itm/UNIVERSAL-AVOMETER-8-MK-5-VERY-NICE-CONDITION/252046668994?_trksid=p2047675.c100009.m1982&amp;_trkparms=aid=777000&algo=ABA.MBE&ao=1&asc=32238&meid=b0956dba68ec4de988ff2f5fa1acc20e&pid=100009&rk=1&rkt=1&sd=261994669171
    Seems they stopped making analog AVO meters a few years back. Not because demand had dropped off but because they could no longer source the required parts economically.
    What I like about an analog meter is that it keeps you more in tune with the physics of what's going on. You know, magnets, coils, current, springs.
    Oh, and you have to have that "anti-parallax error" mirror on the dial.
  • Along with the mentioned Simpson and Triplett meters, you might consider a fine Heathkit IM-18.
    Nice thing about Heathkit is that there is still a strong user community that can provide assistance should said meter require repair. And, documentation is still available through the community also.
    768 x 1024 - 545K
    edited 2015-08-10 15:21
    heater and davejames - you guys have officially moved me from nuts to REALLY NUTS - I've got to get one of these truly OLD SCHOOL meters even if it just for collecting purposes! Very cool...
  • davejames wrote: »
    Your picture of the Heathkit IM-18 VTVM brings back pleasant memories.
    I purchased that kit new, way back when. It was the only Heathkit I purchased new and built from scratch. I had other pieces of Heathkit test equipment but they were purchased secondhand. I bet my old IM-18 is somewhere in my attic.
    Whit,
    Welcome to the club!
    We should try our best to snag these important historical artefacts before they all disappear into land fills.
    When you have yourself sorted with an analogue meter you will of course then need a good old Cathode Ray Oscilloscope. Then you can almost literally see the electrons flying in your circuits.
    That will lead you to vacuum tube technology. With heaters and that empty space you can see where the electrons are really flying around.
    Sometimes I wonder how kids today learn anything of basic reality when they are so far removed from it with their DVM's, digital scopes and Arduinos. So many layers of abstraction away from what is actually happening.
  • I saw a TS-352 on eBay a few months ago. Anybody else remember what that was?
    edited 2015-08-10 16:59
    If you get an unpowered VOM, make sure the input impedance is at least 20K ohms-per-volt. Some cheaper units from back when had inputs a tenth of that value. Of course, VTVMs and FET-input meters still count as analog devices, and they have input impedances in the megohms-per-volt. They require their own power sources, though.
    edited 2015-08-10 17:09
    I have an old Micronta (Radio Shack) 22-207A that I got for Christmas around 1972. It was the cheap Simson clone.
    I promptly plugged it into a wall socket to measure resistance. POP! Blew a resistor. Got another resistor and it's been working up to today. It is good for viewing slow analog signals if you don't have an OScope.
    I was going to say check E=Bay for that model number, but that brings up a newer FET input model. Pretty close and in the $30.00 range.
    But when I googled for my specific model, the decimal point moved to the right.
    http://www.ebay.com/itm/MICRONTA-22-207A-USPP-22207A-/390749865417?pt=LH_DefaultDomain_0&hash=item5afa81c5c9
    http://www.plccenter.com/Buy/MICRONTA/22207A
    I ordered all the 1% resistors from Digikey to replace because of mishap. (All values listed in the manual).
    You can probably find one a a gararge sale for 5-10 bucks.
    No mirrored scale? :)
    TS-352 - Wasn't that George Washington's Wooden Blue Tooth device?
  • Nothing says, uh no, screams old school quite like the Simpson-260 in the black case........
  • There are a million old analog meters around, but if you are looking for the hands down best analog meter ever made, you need to find a Simpson 260. This is the meter by which all others are judged. If you pole engineers old enough to actually know, they will all agree with this.
    ...Tiger
    edited 2015-08-11 13:16
    How about a bald head? :-)
    Yes - frank, Tiger and others - I will look patiently for a used Simpson (or save up for a while - for a new one!). Till then, I bought a inexpensive new one to play with and learn with.
    Thanks for the input, fun and understanding why anyone would want to make such a purchase, and yes Heater - an AVOMETER - just because and an old school CRT oscilloscope are on the list too. (One day I need to hear the story behind that avatar! Thanks for giving a little background on the "Heater" part!)
    I do wish there Heathkit was really still around too - I know there was some talk a while back...
    Publison - great stuff - My Dad and I had a very inexpensive Micronta (Radio Shack) way, WAY back - still in the tool chest and still works perfectly! (will dig it out and play with it too!) I had almost forgotten it!
    edited 2015-08-11 20:10
    Whit,
    The avatar was Sapphire's idea. I fell for it immediately.
    Story starts here: http://forums.parallax.com/discussion/comment/1334767/#Comment_1334767
    edited 2015-08-12 03:04
    Thanks Heater. Great stuff!
  • I know of several that collect vintage vom's. I have one of my fathers vom housed in a wood case from around WW2 era.
    Love the Simpson and Triplet. Many hours on both.
  • What I really miss about the old analog meters is that they were big enough and heavy enough to stay in one place while you were trying to get your probes into an awkward spot.
    With the new tiny digital multi-meters, I often find the meter tipped over by the time I get in position for a reading.
  • Let's not forget, an analog meter helped save Apollo 13.
    edited 2015-08-14 03:04
    At my age, I hope I don't tip over!
    RDL2004 - that's right!
  • What am I offered for a Simpson 260. Needs batteries.
    Jim
    RS_Jim - PM me details, model?, case?, Leads? and I will make an offer! Thanks!
  • For peaking, nulling, and looking for trends, nothing beats analog.
  • My first VOM and first electronics kit project was a Heath kit.
    It was a wonderful way to get started -- precision resistors on a big ganged switch demonstrated all the maths in a very elegant way.
    The project wasn't expensive and got one started on a path with the right tool to move along.
    http://www.heathkit-museum.com/test/hvmmm-1.shtml
    Lots of nostalgia for that big dial and what it taught.
    Great looking unit Loopy - I wish someone still did these sorts of things.
  • PM sent
    Jim
