How long should this repeat loop take with RCSLOW clock @ 20 kHz?
dbpage
in Propeller 1
How long should this repeat loop timeout if the input pin remains at zero?
By my calculations, 10 minutes is 600 seconds, which is 12,000,000 clock cycles at 20kHz. The loop repeats 5000 times, which gives 2400 clock cycles per loop. That seems excessive.
What I'd really like to know is, what value should HR14 be for shutdown to occur in 14 hours? Accuracy is not a biggie.
HR14 := 5000 CLKSET(%000_00_001, 20_000) ' RCSLOW @ 20 kHz repeat while ina[24] == 0 if not HR14-- shutdown ' Remove power if HR14 reaches zeroMy measurements show that it takes approximately 10 minutes to shutdown. Does 10 minutes seem about right?
Don't forget that the Prop take 4 clock cycles per machine instruction. So you would have only 600 machine instructions per loop.
That stills sounds a lot but Spin is compiled to byte codes and each byte code takes many machine instructions to execute it. So may we are in the right ball park here.
You want 14 hours or 840 minutes. You have 10 minutes so you need 84 time more. Set HR14 to 84 * 5000 = 420000.
Having said that, often the reason for using a slow clock speed like this is to save power. In which case I would not have an endlessly executing loop like that but rather do a WAITCNT, for one second say. Use that to count seconds, minutes and hours. This will have the Prop in low power mode most of the time.
Hook up an LED to an I/O pin and turn it on and off in a loop like: This way you can time your loop and see what RCSLOW comes out to for your chip and operating conditions.
This is a sealed system with no access to pins, except Rx and Tx. I'll think about hooking up something to one of those pins.
I like the idea of spending most of the time in waitcnt and checking ina[24] every second or so. The increase in loop machine cycles by the added waitcnt statement will be more than offset by fewer repeat loops.
Now, specifying 20_000 is only accurate if the clock is 20KHz of course. Being an RC clock it may be out a bit and drift around so as it changes from 13 to 33KHz all your program timing will change.
I timed several HR14 values. Using linear regression, I calculate the slope to be approximately 1.21 and y-intercept to be about 1.33. If I subtract 1.33 from the desired number of seconds and divide the result by 1.21, I get a value for HR14 for the number of seconds desired. This suggests an initial overhead of about 33% (including the initial HR14 and CLKSET statements), and a repeating overhead of about 21%.
The resulting timeout periods are reasonably accurate within a few tenths of a percent, plenty accurate for my purposes. As the temperature and battery voltage changes, additional error will occur, but that's OK.
With your help, I now have confidence that there isn't something else wrong with the unit.
Thanks!
What are you making there by the way ?
Sorry, we will have to wait until the NDA is lifted.
Mike Green,
Just remembered that I can access 2 additional pins for a temporary LED or equivalent.
Dennis
Lacking other pins, tx and rx can be fine to serve as outputs for the timing test. Also, if the device happens to have a built-in real time clock, it can measure its own RCslow frequency.
It is a push button. The device seems adequately responsive with the posted code. By my observation of the posted code, ina[24] is checked once per second. Is this not accurate?
Tracy Allen,
After discovering the percentage of time that is spent on overhead for the simple repeat loop, I got spooked if I were to add RTC communication. Communication with the RTC would require the following statements: By my count, the RTC would add an overhead 79 statements, or 316 cycles (at 4 cycles each statement), not including logic to interpret the result. Please convince me that reading the RTC is better than my current code. The RTC would be more accurate, but accuracy is not important. It's the difference between infinity and 14 hours more or less until shutdown.
Note: My RTC allows me to set an alarm interrupt, so I could test for an alarm register or pin, but a pin is not available in this particular device. All pins are allocated. I'm stuck with software access, which is painfully slow at RCSLOW.
Dennis
Pseudosnippet for measurement: For example, if elapsedSeconds comes out at 110 seconds instead of 100, the RCslow clock is slower than 20kHz, and 18181 Hz is a better approximation. For that Prop. At around that temperature.
It's too bad there is not a pin on your setup for the RTC alarm. If it is like the DS1307 and other such chips, the alarm pin can be set up to toggle up and down with a period of 1 second or so. That gives a great way to count down exact intervals with RCslow, or to measure the actual RCslow frequency with stopwatch accuracy.
I like your self-calibration suggestion. That will compensate for variations between individual units. Additionally, the device has enough battery capacity to jump out of RCSLOW periodically (e.g., once every x hours) to check the time.
This is getting interesting.
Dennis
