Security alert! — Parallax Forums
Security alert!
Heater.Heater. Posts: 21,230
edited 2015-07-24 10:35 in General Discussion
First off I have no idea how this works.
However the following scenario worries me:
1) Find a computer available for public use, in a library or bar or wherever. Running XP in this case.
2) Open the browser, Chrome in this case.
3) Go to forums.parallax.com
4) Log in and do ones forum things.
So far so good but then:
5) Log out of the forum.
6) Close the browser.
7) Log out as a guest user of XP and go home.
Some time later...
8 ) Open the same Chrome on the same XP on the same machine and go to forums.parallax.com
9) Hit the "sign in" button.
10) Sure enough that form has your user name and password fields filled already. Just click OK and you are logged in.
WTF? That means I can never disconnect myself from that machine. I have tried by changing the password in the sign in box but it does not work.
Now, you might say it is a dumb Smile stupid thing to log in to anything from a machine you do not trust. Which is true.
However, after some experiments I found that other sites, like raspberrypi.org, do not make it possible for any random stranger to log in as you after you have left.
  • I tested this on several browsers and am unable to reproduce your results. Are you absolutely sure that you logged out of the session? Is it possible that the browser you are using in this instance is remembering your login information? Are you perhaps using a third-party password management app?
    Let's not jump to any conclusions until we understand exactly what you did or didn't do, OK?
    edited 2015-07-23 21:33
    Hi Jim,
    I only noticed this phenomena because I always try to log out of everything before leaving such a public terminal. But in this case I see the damn thing still knows me days later. So today I started to experiment with it.
    I tried to ensure that I was logged out of the forum, closed the browser and logged out of XP before getting back into  XP as guest and revisiting forums.parallax.com
    Sure enough when I hit "sign in" there is my user name and password ready to go.
    Certainly the browser has a "remember me" check box, which I made sure was unchecked. Why  would I ever check such an option in a public place?
    For sure the browser, or something, is remembering my login information.  Surprisingly if I enter a wrong password login fails and it reprompts with the correct password!
    No I am not using any third-party password management app.
    I will play with this some more, another day, when I get back to that machine.
    As it stands there is an XP machine out there that any random person can use to log in as me to the forum!
  • As an aside, does the public machine/browser allow you access to the browser settings?
    There surely must be settings options related to cache and security- where you can remove history and pre-stored usernames/passwords.
    Without naming names, the 3 (most popular?) browsers I have here all have such facility.
    Might help get you cleaned up whilst Jim figures out if something else is possible.
    Good question. I have not tried yet. The machine is running  XP and the browser is Chrome. I doubt that anything has been  done to "harden" it.
    What  surprises me is that forums.parallax.com will let anyone in but raspberrypi.org will not.
  • Good question. I have not tried yet. The machine is running  XP and the browser is Chrome. I doubt that anything has been  done to "harden" it.
    It is the way Chrome is written and the way the Forum software interacts with it. I can tell you that since the new site spun up I've not had to sign back in.
    Now did you remember to sign out on the public one? Its possible that since Chrome expects Google E-mail addresses, such as mine it is possible that this whole business is linked to your Google persona.
    Although this doesn't address why Raspberry Pi's forum works much like those birds at Arduino.....
  • All browsers I've ever used have a delete history option. You usually get a list of things to check, like cache, cookies, logins, etc. At a public workstation, that's always a good feature to use.
  • evanhevanh Posts: 17,252
    That's a generic client side feature for home use, it stores all your entered detials on the local HDD for repeated fast logins. Public facing browsers should have it disabled.
    Yeah, Phil's right. Use the browser's delete features.
    @ Buck Rogers,
    Yes, as I said above I played with this a bit and tried to ensure I was signed out of everything.
    The odd thing for me is that all the login details are there in the defaults of the sign in box for this forum but not others, like raspberrypi.org. @ ??       Yep, good idea.       As I said, offering up your credentials to a public machine is a bad idea. But hey, those creds of mine are no use anywhere else and I'm sure any stranger posting as me here would soon be found out.
  • These are good data points that are going to lead to some interesting configuration issues. We should delete cookies on logout unless the 'Remember Me" box is checked. We do not, as far as I can see in the code, persist login information in the absence of cookies. I am still looking at what exactly is in those cookies.
    My concern here is that the browser is caching or actively storing account information. These features "should be" disabled on public machines but that is not always the case. If nothing else, it's a great social engineering device for dark hats.
    Jim,
    Of course there is no point in worrying about any security while the site is delivered over plain text http.
  • Always with the negative waves. You may be making assumptions about how the client and browser communicate that may not be correct. We can encrypt all of the traffic with HTTPS but are you sure we cannot encrypt anything without HTTPS?
  • VonSzarvasVonSzarvas Posts: 3,639
    edited 2015-07-25 06:55
    That is an unfortunate security risk. But regardless- it is certainly a "feature" of the browser, rather than the website.
    Keeping an eye on the "clear history" button,
    OR even better.... starting a "Private Browsing Session" before logging into membership sites, seems to be one solution.
    Ctrl+Shift+P seems to do that on Firefox. Chrome will no-doubt  have some similar function.
  • SRLMSRLM Posts: 5,045
    Short answer, HTTPS is the only way to do it.
    You could, of course, write some Javascript that will do some encryption and send your data encrypted. But why do you trust the Javascript code itself? Without HTTPS, the Javascript that runs on the client side browser can be intercepted and modified to do whatever an attacker wants.
    The solution is to set up HTTPS. It's not at all difficult since you can just set up a proxy (NGINX, HAProxy) as a SSL termination, and just pass the decrypted requests on to your VPN and servers.
  • I am not disagreeing with you, SRLM. HTTPS does cure a large number of ills. What I don't understand is where was all of the security outrage when everyone used HTTP on the old forum site for years?  At some point, one has to start thinking that some folks are just looking for anything negative to say about this site.
    I will add an SSL cert to the issue list - you can look for that to happen fairly soon.
    Just after the new forum de came online I logged in on my iPhone. I logged out as I wanted to test something and tried to read the forum without logging in. Every time I came back to the forum, it automatically logged me in without going via the login screen.
    I gave up and thought nothing of it. But this would seem to confirm what heater is seeing. iPhone 6+ ios 8.4 safari. Pretty much stock standard.
    The difference is that the new forums are supposed to be an improvement on the old forums, whether or not the problems were publicly reported. By doing this upgrade we as a community are encouraged to revisit all aspects of the forums and look for issues.
    In any case, the HTTPS issue has been reported before. Almost 6 years ago, too:
    http://forums.parallax.com/discussion/118223/secure-log-in-to-parallax-forum
  • SRLM,
    I went to the link you cited and noticed a dead link in your response:
    http://forums.parallax.com/showthread.php?p=760608
    Is this a link that did not get updated during the latest migration or one that was already dead?
  • As it stands there is an XP machine out there that any random person can use to log in as me to the forum!
    I always thought that was the case for 'heater' postings... You mean you're just one person?
    :innocent:
    dgately
    :innocent:
    dgately
    Well said.Sometime after the Linux port to the System Z (as the big blue dressed fellow is now being called) I participated in a normal trade show. (Well normal for a Linux oriented one.) The Sales Engineer for much of this area, wanted to take a photo of myself, since as he said, "The people in my unit are convinced that many people write your e-mail messages to the lists. I wanted to convince them that it was all one person's doing.".
    I have since discovered that on many lists that's also the case, and even the local User's group for the bird also believe that sometimes regarding myself.
    edited 2015-07-24 04:54
    When my cat, Browser, was alive and actively "posting," it was easy to keep my Jekyll and Hyde remarks separate, and I got in way less trouble for it. I mean, who would dare call out a cute kitty for making snide remarks, no matter how biting? Now it's a little harder than before, and my Dr. Jekyll side sometimes wishes he could claim that my account had been hijacked by another party. But ... no such luck. :)
  • TorTor Posts: 2,010
    This doesn't sound like a cookie issue, i.e. when the cookie isn't deleted when you log out, which will keep you "logged in" even after you log out. So it's just the normal 'cached form data' which most browsers do that is the issue here. It certainly helps for your home PC. [Edit: What Cluso99 reports sounds like a cookie issue though! Or a variant where the same cookie would be created for the same user every time, combined with a browser which doesn't delete cookies - often the case on mobile devices. I see that particular issue when you combine the web-interface of any Asus router with an Android browser)[/Edit]. But most browsers will ask before storing the password though - not all form fields are equal. However, a public PC should have the browser configured so that no form data is cached. As a user you cannot be certain of this, so what you should do is to always open a new anonymous tab or window - you can do this both in Chrome and Firefox. Nothing is stored from such sessions. If you're not sure, or if you didn't use an anonymous window, after you have logged out you should go to 'settings' and  find the option to clear browsing data. In Chrome you have to find the 'advanced' setting inside settings, and then select 'Clear browsing data', and tick everything. Particularly 'autofill form data'.
    It's a possibility though that this forum isn't using the correct do-not-cache option for the password field. Sounds like it, unless you said 'yes' to a pop-up that asked about storing the password. I haven't tested the forum for this. In any case it's enough of a problem that the rest (user name, for example) is stored on a public PC. That PC browser should have been configured to not store *any* form data. But as a user you can't be sure, so use the anonymous tab/windows and/or go to settings after the session and clear all the browsing history.
    -Tor
    Jim,
    Sorry to be coming over so negatively. I like to think of it as raising valid concerns. More on them later.
    No, I'm not. The browser and server are communicating in plain, human readable, text. There is some
    vanishingly small chance that is not true, without actually sniffing the line I don't know, feel
    free to fire up wireshark yourself and check if you doubt it.
    No, we cannot encrypt without HTTPS. One could perhaps set up a VPN and tunnel the traffic through that
    is not how it's done on the public internet.
    I would not say I am outraged. As I said, just raising valid concerns.
    You make a good point about the prior lack of concern regarding security issues. Perhaps you have noticed
    that in recent years, since the revelations of Snowdon and others, that security is now more prominent
    on peoples radars.
    edited 2015-07-24 10:37
    The only sensible way of logging in to a forum is through HTTPS. I'm definitely not happy about forums where plain HTTP is used. You can't log in to a forum from a public wi-fi hotspot, for example. Anyone in there with you will be able to watch the communication, with very little technical knowledge. And no, wi-fi hotspot encryption makes no difference - it encrypts the network from outside access, not internally. Unless the web site where you log in supports HTTPS the only safe way to log in from your networked cafeteria is by setting up a VPN connection from your PC or tablet to home, and then log in. But of course that also is in the plain as far as the internet at large is concerned - just not as accessible to laypeople as the public hotspot.
    -Tor
    Edit: As HTTPS creates more strain on the server it's often only used for the actual login - and that's enough to protect your user and password. As the forum itself is public it isn't really important to protect the actual communication (after login), in most cases.
  • Heater, if this is Chrome then are you logged into that? It often saves field entry values and can offer field entry values.
    It's a Chrome browser on XP. It has a guest user account that allows anybody in with no password.I'm not logged into anything else via that machine except occasionally raspberrypi.org. What surprised me is that Chrome presents a filled in login form for this forum but  an empty one for the raspi forum. It's not clear to me why there is that difference.
    Chrome of course tries to be "helpful" and offer up user names and passwords when accessing login forms. When you do login a pop up asks if it should remember the credentials. I always click no or let it time out.
    Clearly one should never be accessing anything serious with credentials that you use in other places via a computer in a public place. There is no telling what that machine is doing with all the data you enter.
    I finally got to clear the browser history in that Chrome on XP on a public machine.
    Sure enough it no longer pre-fills the login dialogue with my user name and password.
    But this gets a bit more mysterious to me.
    Turns out that I can now sign in and sign out of the forum, with or without closing the XP user session, as many times as I like and the credentials do not stick in that form.
    I thought it was perhaps something to do with that little "keep me signed in" check box on the login form but that seemed to have no  effect. Which by the way should not be checked by default.
    I don't get it, what changed?
    The keep me logged in check box should only be about how long the cookie lasts and should not have anything to do with pre-filling login info, that's entirely different. So I can only scratch my head. No idea.
    SRLM,
    I don't think I would have posted a dead link, but I have no idea where it went. Google and the Wayback machine don't have that page in their cache. I assume it was lost on a previous forum upgrade (before the June 2015 upgrade).
  • I have experienced the same "issue" with Chrome/Firefox on other sites, but ONLY when I allow Chrome/Firefox to save the login/password for the site. If I deny it to save the password, I never have this type of issue with either browser. Did you accidentally allow Chrome to save your password?
