Possibly Useful Processing Program — Parallax Forums
Hi, I'm writing the attached processing program for my next project. It outputs the image attached which may be useful to other hobby robotics applications.
1284 x 122 - 5K
  • jmgjmg Posts: 15,200
    Single track Gray Codes are another interesting approach to position encoding.
    As the name suggests they are one-bit change encoder tracks designed to work with multiple spaced sensors. They usually have slightly less than binary-density, but can give simpler mechanical solutions.
    https://en.wikipedia.org/wiki/Gray_code#Single-track_Gray_code
    Image example here is for an even-sensor 360' pitch, but there are solutions for 180' sensor spread
  • Single track Gray Codes are another interesting approach to position encoding.
    That's the plan. I couldn't find a program to generate them, so I wrote my own. The program parameters will allow me to control the size and number of tracks to fit different encoder layouts. I figure I start simple and get more elborate.
