Thread creator can edit tags if needed
mindrobots
I forgot to tag a thread I created earlier today.
I found out I was able to edit the original post and add tags to it. I thought this was kind of a nifty feature with regards to tagging. If you forget something or a thread you started takes an interesting or unexpected turn at some point, you can go in and update the tags to reflect the current topics in the thread.
Oh, and don't forget when you are adding tags, don't forget to use a comma - that triggers the software to accept your tag!
