Incorrect IIC data from P8X32A — Parallax Forums
I just purchased an E1.31 Bridge for DMX lamp control from DIYLEDExpress.com.  Put the kit together, checked voltages, plugged in the ICs and no blinking status LEDs.  The next day my Parallax USB Prop Plug arrived and I tried uploading firmware thinking maybe I'd received a kit with an non-programmed EEROM.
The message was Propeller not found.  A bit more research and it appears the Propeller chip must not be functioning correctly.
The data sheet says if it doesn't find the dongle it goes out and fetches code from the EEROM and if that doesn't work it sets the pins to high impedance and stops.  The problem is that it's not sending the correct data out the IIC pins which I discovered using my MSO 3034 TEK scope with IIC decoding.
The 24LC512 (or 256) requires a command with a bit pattern 1010nnn where nnn matches the address pins on the device.  Then there's a R/W bit and finally two bytes with the address. Clearly the attached screen capture shows an incorrect command.  It's not the EEROMs holding the data line low since the Propeller does the same thing without any attached devices.  There are pull up resistors on both the clk and data lines and they float high.  That can be seen at the start of the trace just after the clock pulses.
To verify that I wasn't going crazy I scoped one of my PIC30F5011 products that has a 1MBit IIC EEROM.  That scope capture clearly shows what should be coming from the Propeller.
Is there something I've missed?  Some other pin on the Propeller that might make it behave incorrectly?  I've followed reasonable anti-static procedures.  The soldering on the board is clean.  It's the first full through hole project I've done in years.  Most everything I build is SMD down to 0603 components and very fine pitch devices.
I've ordered and received shipping notification from Parallax that a P8X32A kit that includes crystal, EEROM regulators etc. and assembled quick start board are on the way. That will take a week.  Shipping parts up to Canada priority USPS is always $25 to $30 US ($40 Cdn,) so generally unless the parts are available from Digikey with $8 shipping I tend not to buy.
Are Propeller chips really that fragile?
800 x 480 - 88K
800 x 480 - 88K
  • I would download the USB drivers. Normally when you plug in the prop plug to the usb on the PC the led's will blink a couple of times even when it's not attached to a prop chip. Then check the voltages on the propeller and the prop plug connections tx and rxd . If you over voltage the prop pins it will blow out.
  • First thing I did was download the correct drivers.  Control Panel Devices shows that the correct driver is in place for that dongle.  Also connecting Rx to Tx with a jumper shows echoed text in both Terminal.exe and also the terminal feature of the Propeller download program.
    To repeat second line of original posting. "Put the kit together, checked voltages, plugged in the ICs and no blinking status LEDs."
    After assembly, using my 6.5 digit Agilent voltmeter I found the 5V supply to the 3V regulator was 5.045V and the 3.3V regulator was putting out 3.287V.
    The kit has sufficient bypassing as far as I can see.  The USB dongle also only puts out 3.3V signals.  Toggling the DTR pin causes the short reset pulse to ground on the dongle which then starts the entire incorrect IIC sequence again.
  • Since the SDA line does go high and low I doubt that it is damaged but it looks more like another pin has shorted across to there or something. It sure is a mystery however I would just solder a pull-up resistor to the SDA line just to make sure as the SDA is not a real open-drain line and what you are seeing could well be when software does drive it high before switching to pseudo open-drain and not being pulled-up which would seem consistent with your scope captures.
  • Looking at the jpg from the site, Pin 1 on the Propeller chip goes towards the Ethernet connector, and pin 1 of the EEPROM goes away from the Ethernet connector.
    Easy to get those confused.
  • I myself have my own PCB boards built up with the prop dip package, ram, and volt regulator's etc. If I have a problem I swap out the prop or ram with known good ones until I find the problem. Most of the time it is the propeller chip because it got spiked with an overvoltage.  In your case I would remove the prop, ram, etc. and build it up on your bread board. Then you can see which component is bad. I always have at least a dozen spare props, ram, crystals on hand in case I have a problem. I looked at the E1.31 bridge online  my guess is maybe your PCB is bad. That is just a guess. Test the components separate and go from there.
  • jcdammeyerjcdammeyer Posts: 4
    edited 2015-07-10 21:18
    A friend had a couple of Parallax 32212 Propeller Proto boards.  Wired it up to power.  Attached the PropPlug.  Ran Propeller Tool V1.3.2 and clicked on Identify Hardware.  Hardware found.  That means everything down to the PropPlug is functional.
    Unfortunately it's a 44pin QFP so I can't sub it into the 1.31 bridge kit.  Clearly I'll have to wait until parts from Parallax arrive.
    Plublison, The are oriented correctly.  Even if they are removed, the IIC protocol should still be correct except an ACK would be missing in the data stream.  In this case there's no ACK because the Control Byte is incorrect.
    Peter, There are 10k resistors on both IIC lines.  That they both go up and down under Propeller control implies they are working.
    DigitalBob, Putting the scope on the Proto board shows the correct IIC sequence on reset.  ie. it matches the IIC with Address Command Byte 50[W] 00 00 50[R] ...
    What it all implies is I'm probably not crazy.  The Propeller chip is defective.
  • Peter, There are 10k resistors on both IIC lines.  That they both go up and down under Propeller control implies they are working.
    If these were true open-drain lines then that assumption would be correct but assumptions are what end up driving us crazy. To solder a resistor and check takes less time than it does to reply on the forum so it would be crazy not to check.
    I'm not sure what you are asking?  There are two 10K resistors on the two IIC lines.  One end of each resistor is at 3.3V on the power rail.  The other ends have continuity to the pins.  How would adding another 10K resistor to 3.3V make any difference?
  • If I bought this board from DIY, express, Christmas or whoever and it did not work. I would contact them and ask for my money back or a tested board that works.
    edited 2015-07-11 02:59
    My point is that since it is such a simple little thing I would just do it anyway and then 60 seconds later I am somewhat wiser rather than scratching my head about it. Yes, there is a resistor in there, I could check continuity and resistance and I probably would anyway. Troubleshooting involves being methodical and not leaving any stone unturned by making assumptions. Certainly the simple things can be addressed quickly at least.
    There is no insult intended nor should one be taken.
  • The Prop bootloader drives SCL high and low, SDA however is never driven high, which I've verified with my bread-boarded Prop.  That SDA idles high at the beginning, and returns to idle high between the messages--between writing the register address and starting the read--shows the pull-up is okay.
    Pull-ups also have nothing to do with comms to the Prop Plug.  Since the IIC and serial comms both fail, it does seem like there's a problem with the Propeller itself, though I've never heard or imagined one could fail in this manner.
