Can I disable my default message sort? — Parallax Forums
It appears that greater minds have decided that the "voting" system for message display stays.
I hate it!  I'm simply not adaptable enough to work with this..
Can I turn this off in my profile somewhere, or could this switch be added so that messages sort by date (like they used to) by default?
Thank you.
    edited 2015-07-03 03:51
    There's an option within the thread to sort by date. I changed it once and all the other threads have sorted by date since.
    Edit: The option is directly over my name. Mine says: 1 Comment sorted by Votes Date AddedI betting yours has "Votes" in bold. Select "Date Added" and it should remain in that setting in the other threads.
  • Sir you are a gentleman and scholar!   It even stayed fixed after I logged out and logged back in.
    THANK YOU!
    THANK YOU!
    You're very welcome Jeff.
    Did I ever tell you I learned a lot from your "Propeller Cookbook"? I did.
    I never attended one of your Unofficial Propeller Expos but I always watched as much as I could online.
    THANK YOU!
