Mini Arc Furnace And Small Castings
idbruce
As many of you know, I am interested in the subject of metal casting, however my current setup is labor intensive and is restricted to an outdoor activity. Over the years, there have been many times that I needed a small and simple cast, and furthermore, many times this need occured during the winter months. So occassionally I have been doing a little research on building a small indoor furnace, to handle such tasks. While researching mini arc furnaces this morning, I stumbled across this YouTube video, which caught my interest, and thought that some of you might like it also.
https://www.youtube.com/watch?v=JIlZsuRc9jQ
EDIT: And here is another one of his YouTube videos, which shows other aspects of this project:
https://www.youtube.com/watch?v=VTzKIs19eZE
I just happen to have a huge old microwave oven transformer here....
Besides being informative, there are several things that I really like about these videos, but most importantly is the recycling of a couple objects to obtain crucial parts. Additionally, I like the idea of creating two furnaces (crucibles) from one inexpensive fire brick, however, I will most likely store the carbon rods in a seperate brick and perhaps create a seperate furnace for brass, bronze, aluminum, copper, and steel.
Those videos definitely present possibilities.
Anyway, between us we needed a lot of ali to cast bases for steam/hot air engines and whatever. All of a sudden all kinds of coat hooks, door handles and rails were disappearing from all over the place.
Let's say it was premature recycling
I have some that are too short to use in a searchlight but would work fine for this. Also have some that are longer and were probably for a projector and don't really have a need for those either.
Robert
Premature recycling..... Yea, there is a lot of that going on New homes stripped of wiring and copper plumbing. They catch those premature recyclers all the time around here. Nice phrase.
"But your Honor, I was not stealing... I was just doing a little premature recycling to make my pockets a little greener"
http://mad-science.wonderhowto.com/how-to/melt-metal-with-modified-microwave-oven-transformer-0139556/
"But Sir, we were only doing a little premature recycling to support a valuable part of our education here"
No doubt that would have resulted in a severe caning and a week of detention after school. Bet they don't do that in schools now a days either.
Anyway, it was a lot of fun doing that sand casting.
Pouring molten metal into sand and then breaking away the sand to see the result.... Cool stuff. I am sure I would have a lot more fun with it, if I had a special location set up for just casting, and a better furnace/burner setup would be nice also.
For instance, I have been wanting to make this burner for a very long time, but it just doesn't make sense, until I build a new furnace:
http://www.backyardmetalcasting.com/oliverburner1.html
EDIT: And here is the rough draft of my new furnace that I designed many years ago, but still have not made it yet.
Here is a device I used to maintain while stationed on the USS Hoist. (Filthy thing to maintain let me tell you) Maybe get some ideas for the automatic feed of the arc. rods....
http://www.maritime.org/doc/searchlight24/index.htm
FF
Pretty cool document. Thanks for sharing.
http://www.searchlightparts.com/searchlights/wp-content/uploads/2014/03/SperrySearchlightCatalog.pdf
They are pretty cool to see running. The GE had a more elegant method of controlling the negative feed with a dual magnetic clutch and is a bit more tolerant to voltage drops than what Sperry used. Otherwise they work the same. They keep rotating the carbon so it burns evenly. I don't think many of the regular arc lamps did that...
Robert
