SOLVED: Launching PASM/SPIN in 8th cog.
Problem:
Current application which is running fine but using 7 cogs and need to add 2 programs which will be swapped out from time to time. One is a straight forward Spin program so no problem with that one but the other is a PASM program which originally used a small SPIN program to launch it but obviously with 7 other cogs already running that won't work.
I tried to just add the PASM as a 2nd DAT segment to my Top Object and changed the entry point name but the compiler complained about duplicate label and variable names.
As all my 7 PASM files are rather large and developed over time, there are duplicates of many label and variable names. No problem when they resided in separate files and all had their own Spin programs to launch them. I would simply start. launch PASM, then stop the SPIN program.
I certainly can go and rename everything so the compiler is happy but I wonder if I am missing something very elementary.
Using the Propeller Tool for programming.
Thanks.
Thanks.
Yes, I think you are. You can place the PASM code in a separate object and have it launched from the separate object.
Remember there is no limit to the number of objects a single cog (running the Spin interpreter) can access.
If you could post either your whole code of the part you're wondering about I'm sure we could help.
Here is where I get wrapped around the axle and since I began using the prop I have always fought launching something in the final available cog so I always tried to make that a Spin program without an associated PASM file.
Let me try to explain in pseudo code.
Top Object pseudo code:
8 Cogs running
1) Stop PASM_code_A 'now one cog is free
2) Obj_Code_B.Start [pure spin code here so I only need 1 free cog and I have one]
3) No longer need Obj_Code_B but now need PASM_code_A" to run.
4) cogstop(Cog~ - 1) [stop Obj_Code_B and now 1 free cog remains].
Now this is where I get lost in attempting to start PASM_code_A from the Top Object.
With 1 free Cog how do I restart PASM_code_A again without the need of a Spin file and a cog unless PASM_code_A's code resides as a 2nd DAT segment in the Top Object file?
Again, if I must, renaming all my labels/variables is not a huge thing but if I can get it through my thick skull how it should be done it would make things easier.
As I showed earlier, the PASM code doesn't need to be in the top object for the cog running the top object to start it. If the DAT segment (containing the PASM code) is in another object, the top object just needs to call a Start method to get the PASM code launched and then control would return to the top object.
I had PASM_Code_A in its own Spin file with just a Start and Stop method and the spin portion would just launch the PASM then stop. This is why in this program I had 7 cogs used but now I need a way to get a PASM running with only 1 free cog.
If I tried to now use the Top Object to re-launch this same program I am assuming I need 2 free cogs again.
From Top Object:
Midi Object:
What is the proper method to start a PASM program if you only have 1 free cog?
Boy, I don't know if I can recover all the hair follicles I have lost over the years avoiding PASM if I only had 1 free cog.
You have made my day!
The act of calling the start method doesn't launch a new Spin cog. The call to "MIDI.start" only launches the single PASM cog. You only need one cog free when you call MIDI.start.
Edit: I hadn't seen post #8. It looks like you understand now.
Thanks again to both of you gentlemen.
