L298 and anti-phase PWM
Mickster
I have one of the Ebay-type dual H-bridge amps based on the the above. I was wondering if there is a way to configure it for anti-phase PWM where a 50% duty cycle results in zero amplifier output.
I seem to remember achieving this with a 18200 based amp (?) where I tied a pin high and applied the PWM to the Enable....I don't remember.
Cheers!
MIckster
Cheers!
MIckster
The L298 documentation shows the push-pull as internally hard-wired inversion of each other and doesn't seem to indicate any requirement for dead time on the enable signals. The functional diagram isn't any help ... presumably such details are hidden but taken care of.
EDIT: The documentation says the Enables do have to be low upon power up of the power supply. So, can't just tie those controls high. I guess a capacitor plus pullup-resisitor plus pull-down diode would be enough.
