Video Isolation
BTX
Hi all.
Does anybody did a schema to isolating the video output from the Pchip ?
Or, any ideas of how to do it ?
Cheers.
Cheers.
Just found the HCPL-4562 opto in DigiKey, I think it could be great !!
Thx'u
Hi Alberto!
I did a couple of designs with this device and there is a little bit of tweaking necessary IIRC. If you want a copy of the circuit that works just let me know.Remember that you will need an isolated DC-DC converter with filtering or linear regulation to drive the output stage cleanly. However I would be more inclined to build in the isolation at the digital stage if that were possible. For instance, if it's composite video you could easily have 3 channel solid-state isolator chip with it's own built-in DC-DC converter. It's so much simpler and there is no need for any kind of trimming then. I've used ADUM5402s but there is quite a few to choose from these days.
