Trying to understand the PASM waitpeq command — Parallax Forums
jaschandlerjaschandler Posts: 23
edited 2015-06-04 21:06 in Propeller 1
I just want to know if I'm using the waitpeq command correctly.
  │ ADS1131 18-Bit ADC for Bridge Sensors    │
  │ Author: James L Chandler                 │
    The DATA READY/DATA (DRDY/DOUT) output pin serves two purposes:
      1.  It indicates when NEW Data is ready to be read by dropping from its normally high
          state to low.
      2.  Afterwards on the first rising edge of SCLK, the DRDY/DOUT pin changes its func-
          tion and it then starts
          outputting the ADC converted data w/ the (MSB) most significant bit first i.e.
          bit 17, bit 16, bit 15,...bit 2, bit 1,and the last bit 0.
          Data are shifted out on each subsequent SCLK rising edge.  After all 18 bits have
          been passed, the DRDY/DOUT
          pin is then forced high on the next SCLK rising edge where it remains high until
          the next data cycle is about to start.
    This program waits while monitoring the DRDY/DOUT pin.  As soon as this pin drives
    negative this alogrithim activates.
    It then looks for the first rising edge off the SCLK pin.  The algorithm then measures
    DRDY/DOUT for a high or a low state.
    A 1 (logic high) or 0 (logic low) is then pushed onto the stack.  Once the 18th data
    bit has been read and placed on the stack
    the algorithm pulls data off the stack in (LSB) least significant bit first.  The data
     is then returned in 5 digit Hex format
    "The positive full-scale input produces an output code of 1FFFFh and the negative full-
    scale input produces an output code of 20000h."
    IN BINARY TWO COMPLEMENT format.
          5.0V    ADS1131     3.3V
             ┌─────────────┐              P8X32A
           └──┤AVDD     DVDD├─┘  1KΩ    ┌─────────────┐
              │    DRDY/DOUT├─────────┤ P27         │   P27 = Data ready/Data out
              │         SCLK├─────────┤ P26         │   P26 = Clock for syncronizing w/
              │             │           │             │   Data ready/Data out
              │         PDWN├─────────┤ P25         │   P25 = Activate on 1 or 0 place A
              DC in sleep mode          │             │
            ┌─┤        SPEED├─────────┤ P24         │   P24 = Speed select for the ADC:
             └─────────────┘           └─────────────┘           1. A logic zero 0 sets
            the chip to 10 samples per second (SPS) or
        2. A logic one (high)
        sets the chip to 80SPS
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
VAR
  long  Cog, TestVar
OBJ
  dbg   :       "PASDebug"                '<---- Add for Debugger
PUB main
  Cog := cognew(@entry, @TestVar) + 1
  dbg.start(31,30,@entry)                 '<---- Add for Debugger
PUB stop
  if Cog
    cogstop(Cog~ -  1)
DAT
                        org     0
entry
'  --------- Debugger Kernel add this at Entry (Addr 0) ---------
   long $34FC1202,$6CE81201,$83C120B,$8BC0E0A,$E87C0E03,$8BC0E0A
   long $EC7C0E05,$A0BC1207,$5C7C0003,$5C7C0003,$7FFC,$7FF8
' Test code with modify, MainRAM access, jumps, subroutine and waitcnt.
StartupADS1131
                        mov         dira,START            ' P26 & P27 output low
                        mov         outa,POWER            ' P26 is shifted high "1" the ADS1131 is now on
                        waitpeq     $1, DROUT             ' Wait "P25" DROUT to go high
                        waitpeq     $0, DROUT             ' Wait "P25" DROUT to go high
                        mov         Counter, #5           '
:loop
                        waitpeq     $1, SCLK             ' Wait "P25" DROUT to go low
                        nop
                        djnz        Counter, #:loop wz    ' Loop 5x because the measurement is not yet reliable
                        mov         Counter, #19          ' Set Counter for next loop
ReadData
:loop
                        waitpeq     SCLK,SCLK             ' Wait for SCLK to go positive
                        nop
' VARIABLES
SCLK                    long    |<24        ' Pin P24       $0100_0000
DROUT                   long    |<25        ' Pin P25       $0200_0000
POWER                   long    |<26        ' Pin P26       $0400_0000
SPEED                   long    |<27        ' Pin P27       $0800_0000
START                   long    $0C00_0000
ZERO                    long    $0000_0000
HIGH                    long    $FFFF_FFFF
' res variables are always last
Counter                 res     1
                        fit     496
  • tonyp12tonyp12 Posts: 1,951
    edited 2015-06-02 12:25
    It's the Prop that has to provide the clk,
    SCLK: Digital input Serial clock: clock out data on the rising edge.
    P.S WAITPEQ does not wait for an edge so if the state is still correct from the last one you have to wait for WAITPNE first
    edited 2015-06-02 15:53
    Your waitpeq instructions have $0 or $1 in the destination. These are not immediate operators, but addresses. So the patterns that it waits for will be the contents of those addresses. If you want the pattern to be a 1, you have to do it this way:
    waitpeq one,SCLK
    one     long    1
  • jaschandlerjaschandler Posts: 23
    edited 2015-06-02 17:38
    I'll try that and see what happens...
    edited 2015-06-02 21:01
    Ok Phil I rid of the $1 & $0 and replaced them as suggested by one & zero
    I also changed
    The "waitpeq one, DROUT" locks up the processor. I find this odd because it's shows high and 90% of the time it should be.
    I also took Tony's advise and changed the rest of my waitpeg commands to waitpne i can see where this may be a better choice.
    However if I comment out the "waitpeq one, DROUT"
    the program will pass through "waitpne one, DROUT" without any problems
    but it then locks up at "waitpne zero,SCLK" so I changed it to "waitpne one,SCLK" and that works.
    The ADS1131 has it's own clock and requires the end user to read the data using its clock. Doing so I was glad to see pass through...however this would have me sync to the negative going direction of SCLK and I need to be on the positive going side,
    The code now goes through but I need to look for the first positive SCLK pulse and compare that with DROUT to know what state that data pulse is in.
    I thought the waitpeq stopped the cog until in my case DROUT is positive. It's positive 90% of the time so why is it waiting forever? What am I missing in how waitpne works?
    And why does the COG pass through SCLK as it goes negative but not when it goes positive. I never found anywhere where someone was able to read an ADS1131 ADC chip. I really want the propeller chip to be the one that reads the data. There are so many things I can do with a working scale. And I seem to be hammered down with something that should be easy. So without further rambling here is the code right now:
    {{&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
      &#9474; ADS1131 18-Bit ADC for Bridge Sensors    &#9474;
      &#9474; Author: James L Chandler                 &#9474;
      &#9474;                                          &#9474;
      &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
             1         2         3         4         5         6         7        8          9
    1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901
              state to low.
              5.0V    ADS1131     3.3V
               &#61463;  &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488; &#61463;             P8X32A
               &#9492;&#9472;&#9472;&#9508;AVDD     DVDD&#9500;&#9472;&#9496;  150&#937;   &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
                  &#9474;    DRDY/DOUT&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P27         &#9474;   P27 = Data ready/Data out
                  &#9474;         SCLK&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P26         &#9474;   P26 = Clock for syncronizing w/
                  &#9474;             &#9474;           &#9474;             &#9474;   Data ready/Data out
                  &#9474;         PDWN&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P25         &#9474;   P25 = Activate on 1 or 0 place A
                  DC in sleep mode          &#9474;             &#9474;
                &#9484;&#9472;&#9508;        SPEED&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P24         &#9474;   P24 = Speed select for the ADC:
                &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;           &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;           1. A logic zero 0 sets
    Example #1 (Set Pin as a OUTPUT - Preset with LOW)
                  mov     t1,             #1        wz      '     Configure Pin
                  shl     t1,             Pin               '          Create Mask with t1
                  muxz    outa,           t1                '          PreSet DataPin LOW  "0"
                  muxnz   dira,           t1                '          Set DataPin to an
        OUTPUT              "1"
    Example #2 (Set Pin as a OUTPUT - Preset with HIGH)
                  muxnz   outa,           t1                '     PreSet DataPin HIGH "1"
                  muxnz   dira,           t1                '     Set DataPin to an OUTPUT "1"
    Example #3 (Set Pin as a INPUT )
                  muxz    dira,           t1                '      Set DataPin to an INPUT "0"
    CON
    'SCLK    P24
    'DROUT   P25
    'POWER   P26
    'SPEED   P27
    VAR
      long  Cog, TestVar
    OBJ
    PUB main
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
    '                        waitpeq     one, DROUT             ' Wait "P25" DROUT to go high
                            waitpne     one, DROUT             ' Wait "P25" DROUT to drive low
                            mov         Counter, #5            '
    :loop
                            waitpne     one,SCLK
                            nop
    ReadData
    :loop
                            nop
    ' VARIABLES
    one                     long    1
    zero                    long    0
    ' These variables are always last
    Counter                 res     1
                            fit     496
    edited 2015-06-02 21:26
    Your "one" has to be a mask that pairs with the source operand. IOW, if the source is SCLK, setting the destination operand to SCLK is probably what you want. IOW, the two operands have to correspond bit-for-bit.
  • edited 2015-06-03 00:28
      &#9474;                                          &#9474;
              state to low.
              5.0V    ADS1131     3.3V
               &#9492;&#9472;&#9472;&#9508;AVDD     DVDD&#9500;&#9472;&#9496;  1K&#937;    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    CON
    VAR
      long  Cog, TestVar
    OBJ
    PUB main
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
                            mov         Counter, #5           '
    :loop
                            nop
    ReadData
    :loop
                            nop
    ' VARIABLES
    Counter                 res     1
                            fit     496
    I haven't been able to make the literal symbol ( # ) work reliably with the WAITPEQ and WAITPNE statements. Have a look at WAITPEQ in the manual for example. WAITPEQ State, Mask will wait until INA ANDed with Mask matches State. The program will then continue with the next instruction.
    WAITPEQ DROUT, DROUT    'wait until DROUT is high  ( DROUT AND INA == DROUT )
    WAITPEQ ZERO, DROUT     'wait until DROUT is low  ( DROUT AND INA == ZERO )
    These two constructs work for everything that I've been doing so far.
    I imagine the literal operator might work for pins 0 through 8 since a literal value is only 9 bits but I haven't tried it.
    Sandy
    edited 2015-06-03 01:10
    Untested, HTH.
    DAT
                            org         0
    entry
    StartupADS1131
                            mov         dira, START           ' P26 & P27 output low
                            mov         outa, POWER           ' P26 is shifted high "1" the ADS1131 is now on
    ' the two insns below make sure you have a high/low transition
    {optional}              waitpeq     DROUT, DROUT          ' Wait "P25" DROUT to go/be high
                            waitpne     DROUT, DROUT          ' Wait "P25" DROUT to drive low
    ' according to comments you want to wait for rising clock edges
                            mov         Counter, #18          ' Set Counter for read loop (18 bits)
    :loop                   waitpne     SCLK, SCLK            ' clock must be low to get through here
                            waitpeq     SCLK, SCLK            ' clock is now high (low/high transition)
    '                       capture and store bit(s)
                            test        DROUT, ina wc         ' sample bit (DROUT)
                            rcl         Data, #1              ' store bit (use rcr for opposite order)
                            djnz        Counter, #:loop       ' for all bits
                            waitpeq     $, #0                 ' wait here
    ' VARIABLES
    START                   long    |<26 | |<27
    Counter                 res     1
    Data                    res     1
                            fit
    edited 2015-06-03 05:00
    Thank You everyone;
    Kuroneko I see my errors and have a better understanding of waitpeq & waitpne. I changed my code as follows; however a new problem has cropped up. It will now wait at "waitpne SCLK, SCLK".
    I found this to be rather odd so I looked at the cog memory and found:
    Addr Value Label
    012 $F03C2E17 -264491497
    013 $613C31F2 1631334898
    014 $34FC3A01 888945153
    015 $E4FC3811 -453232623
    016 $F07C2C00 -260297728 SCLK <==I did not expect to see this happening
    017 $01000000 16777216 DROUT This is the pin for SCLK
    018 $02000000 33554432 POWER It continues but they are all off one
    By looking at this I can see why I get past DROUT because it is actually looking at the SCLK pin. The SCLK command stops because of what it is looking for.
    All my variables have slipped one throwing everything off. How is this happening and how do I prevent it?
      &#9474;                                          &#9474;
              state to low.
              5.0V    ADS1131     3.3V
    CON
    'SCLK    P24
    'DROUT   P25
    'POWER   P26
    'SPEED   P27
    VAR
      long  Cog, TestVar
    OBJ
    PUB main
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
                            mov         Counter, #18            '
    ' VARIABLES
    Counter                 res     1
    Data                    res     1
                            fit
    edited 2015-06-03 05:18
    Assuming the insn at 012 is waitpeq SCLK, SCLK then SCLK is correctly located at 017. The remainder looks OK as well (code-wise). Not sure why the labels are mismatched though (a PASD issue perhaps, Andi?)? How did you determine that it stops at the waitpne?
    As a quick test, you could use an edge counter monitoring that pin (ctra := %0_01010_000 << 23 | 24) load frqa with a non-zero value and check the value of phsa after you applied power to the converter. Just to confirm that there is a clock.
    From the datasheet it looks like SCLK is a digital input. So who - if not the propeller - is generating said clock?
    edited 2015-06-03 06:18
    The ADS1131 tech states that it has it's own clock. They expect the processor connecting to it to sync to it for the read.
    edited 2015-06-03 06:38
    I go along with the internal clock feature but page 10 tells me that SCLK needs an external clock to shift out the data. Not having a clock there certainly explains your lockup on waitpxx.
    Also, your pin assignments don't seem to match the diagram:
    5.0V    ADS1131     3.3V
    edited 2015-06-03 07:22
    The internal oscillator is strictly for internal functions like the signal chopping, filtering, and performing the adc conversion. Shifting data out requires an external SCLK signal on pin 15 of the chip. The data must also be shifted out before new data are updated or the current data will be overwritten.
    edited 2015-06-03 12:17
    The drawing I provided was not the one I was using I have corrected that...my bad.
    5.0V    ADS1131     3.3V
                  &#9474;    DRDY/DOUT&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P25         &#9474;   P27 = Data ready/Data out
                  &#9474;         SCLK&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P24         &#9474;   P26 = Clock for syncronizing w/
                  &#9474;         PDWN&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P26         &#9474;   P25 = Activate on 1 or 0 place A
                &#9484;&#9472;&#9508;        SPEED&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#9472;&#9472;&#9508; P27         &#9474;   P24 = Speed select for the ADC:
    From what I see on the PPDB board drawings that I'll need to write code to toggle P25 so that this will work...but this will waste another cog.
    Do I need another outside chip? I'm thinking out loud...this is all new to me.
    edited 2015-06-03 12:45
    No, you do not need another cog. See page 10 Figure 6. 18-Bit Data Retrieval Timing of the TI data sheet for a diagram. When DRDY/DOUT (pin 25) goes low data is available. At that point do the following:
    1 - Toggle SCLK (pin 24 from low to high to low) to place the MSB bit data out to DRDY/DOUT
    2 - Read DRDY/DOUT in to a variable and shift left one bit
    3 - Repeat for the other 17 bits (or as many as you want)
    PS - You should toggle the SCLK 19 times per read even if you don't need all the bits in order to set DRDY/DOUT back to high so you can wait for it to go low at the next conversion.
    edited 2015-06-03 12:58
    Thank You ... that makes sense.
    I hate bothering people but in the end I'm learning and moving forward lol
    edited 2015-06-03 14:28
    You're welcome, and don't hesitate to ask questions on the forum. Helping out and sharing knowledge is it's main purpose, and there are a lot of smart and helpful people on it that are happy to do so.
    edited 2015-06-03 14:31
    I'm still getting that sliding variable problem. let me try a picture this time:
    SCLK is still slewed wrong...
      &#9474;                                          &#9474;
              state to low.
              5.0V    ADS1131     3.3V
                  &#9474;             &#9474;           &#9474;             &#9474;         DC in sleep mode
        per second (SPS) or
    CON
    'SCLK    P24
    'DROUT   P25
    'POWER   P26
    'SPEED   P27
    VAR
      long  Cog, TestVar
    OBJ
    PUB main
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
    :loop
                            mov         Counter, #18            '
    :dataLoop               muxz        SCLK, SCLK wz         ' toggle high/low so that DROUT will show data
                                                              ' Now I need SCLK to remain low/high for at least 100ns
                            test        DROUT, ina wc         ' sample bit (DROUT) 4 clks = 50ns
                            rcl         Data, #1              ' store bit (use rcr for opposite order) 4 clks 50ns _ 50ns = 100ns
                            djnz        Counter, #:dataLoop   ' for all bits 4 clks = 50ns + 100ns = 150ns
                            muxz        SCLK, SCLK wz         ' toggle DROUT back to high so it will go low at the next conversion 200ns
                            jmp         #:loop                ' no loop 8 clks 100ns + 150ns = 250ns
    ' VARIABLES
    Counter                 res     1
    Data                    res     1
                            fit
    403 x 637 - 224K
    403 x 637 - 126K
  • edited 2015-06-03 19:57
    DAT
    org 0
    entry
    StartupADS1131
    :loop
    mov Counter, #18 '
    ' VARIABLES
    Counter res 1
    Data res 1
    fit
    [/code]
    I'm not seeing where the z flag is being set prior to the first muxz call. If you just want to toggle the state of the SCLK pin you could use xor outa, SCLK instead.
    Sandy
    I don't think the last long definition is doing what you intended.
    START long |<26 | |<27 resuls in $08000000 not $0C000000
    I think it needs to be:
    START long %11 <26
    edited 2015-06-03 20:24
    It looks right to me: i.e. $0400_0000 | $0800_0000. Explain?
    edited 2015-06-03 20:37
    In my original code I specified "START long $0C00_0000" Kuroneko suggested |<26 | |<27 and that actually works.
    Alexander thanks I'll look at that and correct it I was looking at shifting the SCLK (something I've never done).
    But for the life om me I can't figure out why the code in the variables lined up and now they are off. SCLK is no longer pointing to $01000000 but after loading it into the chip it SCLK is pointing to $F07C2C00 even though the code looks right something in the variable defining has happened and I can't see it.
    Here it is lined up
    Suddenly it wrong
    382 x 402 - 142K
    344 x 355 - 119K
    After looking over your code I think you are misinterpreting what the PASM instructions are doing. I will go over your code in the morning, but in the meantime you could go through some of the PASM tutorials and look at some of the code in the OBEX.
    edited 2015-06-03 20:46
    I didn't understand it either at first but | is bit wise or so 4 hex (0100) bit wise or with 8 hex (1000) and ends up with C hex (1100). I tried re-using $0C00_000 and my variables are still shifted. I liked the bit wise or idea it fall in line with everything else.
    edited 2015-06-03 20:50
    Our posts are crossing in the ether. Kuroneko is one of the best PASM programmers on the forum so if he suggested it then it should work, but when I looked at the debug output the value was $08000000 which is not correct unless that long is being used for something else after the pins are set to outputs. It could be that some code is overwriting cog registers. Missing #'s will do that.
    edited 2015-06-03 21:00
    In the .gif from post 18 the value is $08000000. Should it not be $0C000000 ?
    edited 2015-06-03 21:37
    It is $0C00_0000. The label refers to the value on the following line. IOW START is at address $1C, not $1B (verified by counting instructions from the org).
    edited 2015-06-03 22:42
    I can't see why the code I now have will not work. Unless someone can explain why my variables are off kilter when viewed than my next move will be to remove the debugging scripts in the code and plug in the one pin driver board for my PPDB board and have this code go to six LED display on my board. If it works Like I suspect it will than I will report a bug to the PASD (Debugger) site. I think I'm chasing a bug that the Debugger is introducing at this point.
      &#9474;                                          &#9474;
              state to low.
              5.0V    ADS1131     3.3V
        per second (SPS) or
    CON
    'SCLK    P24
    'DROUT   P25
    'POWER   P26
    'SPEED   P27
    VAR
      long  Cog, TestVar
    OBJ
    PUB main
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
                                                              '   ADS1131 is now on
    :loop
                            mov         Counter, #18            '
    :dataLoop               xor         outa, SCLK            ' toggle high/low so that DROUT
                                                              '   will show data
                                                              '   low/high for at least 100ns
                                                              ' 50ns + 50ns = 100ns
                            xor         outa, SCLK            ' toggle DROUT back to high so it will go low at the next conversion
    START                   long    |<26 | |<27               ' P26 bitwise or P27 $0C00_0000
    'These variables are always last
    Counter                 res     1
    Data                    res     1
                            fit
    edited 2015-06-04 06:44
    At first glance the only thing I can see is that the last xor needs to be before the djnz so SCLK is low when entering dataLoop.
    May need a delay nop as well.
    edited 2015-06-04 07:16
    Try this. Added nop's for delays and xor's to toggle as needed. Delays are a bit more than required but the conversion rate is so slow that it does not matter.
      &#9474;                                          &#9474;
              state to low.
              5.0V    ADS1131     3.3V
        per second (SPS) or
    CON
    'SCLK    P24
    'DROUT   P25
    'POWER   P26
    'SPEED   P27
    VAR
      long  Cog, TestVar
    OBJ
    '  dbg   :       "PASDebug"                '<---- Add for Debugger
    PUB main
    '  dbg.start(31,30,@entry)                 '<---- Add for Debugger
    PUB stop
      if Cog
        cogstop(Cog~ -  1)
    DAT
                            org     0
    entry
    StartupADS1131
                            mov         outa,POWER            ' P26 is high "1", all the other pins are low
                                                            ' the  ADS1131 is now on
    ' the two insns below make sure you have a high/low transition - 250nS
    :loop
    {optional}              waitpeq     DROUT, DROUT          ' Wait "P25" DROUT to go/be high - 6+ clocks 75nS
                            waitpne     DROUT, DROUT          ' Wait "P25" DROUT to drive low  - 6+ clocks 75nS
                            mov         Counter, #18          ' Reset Counter to get 18 data bits - 4 clocks 50nS
                            mov     Data,#0                   ' Clear Data before getting new data
    ' Loop to acquire data from ADC - 9 x 50 x 18 = 8100 nS + 50 = 8.15uS
    :dataLoop               xor         outa, SCLK            ' SCLK is now high so that DROUT
                                                              '   will show data
                            nop                                  ' Now I need SCLK to remain
                            nop                                  '   low/high for at least 100ns
                            test        DROUT, ina wc         ' sample bit (DROUT) 4 clks = 50ns sets carry if input to pin is high
                            rcl         Data, #1              ' store bit (use rcr for opposite order) rotate left to lsb of Data
                            xor         outa, SCLK            ' toggle SCLK back to low
                            nop                             ' 100nS delay
                            nop
                            djnz        Counter, #:dataLoop   ' 4/8 cycles per bit
    ' Finished acquiring data. Now toggle SCLK once more to set DROUT pin high to wait for next acquisition 5 x 50 = 250nS
                            xor         outa, SCLK            ' toggle SCLK back to high
                            nop                               ' 100nS delay
                            nop
                            xor         outa, SCLK            ' then toggle SCLK back to low so DROUT will go low at the next conversion
                            jmp         #:loop                ' Go get next reading. No loop 8 clks 100ns + 150ns = 250ns
    Counter                 res     1
    Data                    res     1
                            fit
    edited 2015-06-04 07:44
    Well that's the problem. The $0800_0000 is for P27. Because of the offsets my program crashes with "mov Counter, #18" now that's rudimentary but Counter is not pointing to the right storage point and the processor will not let it store to the address assigned. This sliding thing has me perplexed.
