X-Band motion detector
Hello,
I have this sensor and am trying to compare it with the mini-PIR sensor. It does not seem to function so well when there is no motion. The output pulses at about 4-10 hertz when there is no motion at all anywhere in the room. See the video link that shows the output with no motion. Is there something wrong with this sensor, or is there a way to filter this extranious information out?
http://youtu.be/rZDBa7RZ1F4
Marcus
Marcus
BUT!!! Then I thought maybe I should remove the XBee S6B I had on the board, and voila! It started working perfectly. So, I'm not sure exactly what was causing the issue, but if you're using the X-Band motion detector with an XBee on an activity board, keep this in mind!
Marcus.
