Propeller and smt 16030 digital temp sensor - very basics
Hi
I just managed to get a Propeller1 and Smt16030 digital temperature sensor. I don't have previous experience about Propeller or microcontrollers or that temp sensor.
Could somebody point me to the correct direction for reading a temperature using that temp sensor and Propeller. I have looked some datasheets and currently I just need to print the temperature using Parallax Seriel Terminal.
Also I just blinked some leds using Propeller
Here's what I came up with:
DAT programName byte "Smt16030", 0 CON { This program might show how to use read from a SMT16030 sensor. By Duane Degn 11 May, 2015 } CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq MS_001 = CLK_FREQ / 1_000 US_001 = CLK_FREQ / 1_000_000 SCALED_MULTIPLIER = 10_000 SCALED_DECIMAL_PLACES = 4 SCALED_CONVERSION_DENOMINATOR = 47 ' = .0047 * 10_000 SCALED_CONVERSION_SUBTRACTION = 3200 ' = .32 * 10_000 SMT16030_PIN = 16 ' Connect to sensor with at least a 3K ohm resistor. 10K ohm should work fine. VAR long scaledTemperature ' make this global so it can be used from other methods OBJ Pst : "Parallax Serial Terminal" Format : "StrFmt" PUB Setup Pst.Start(115_200) repeat result := Pst.RxCount Pst.Str(string(11, 13, "Press any key to start program.")) waitcnt(clkfreq / 2 + cnt) until result Pst.RxFlush Pst.Clear TestSensor PUB TestSensor | startLow, startHigh, endTime, timeHigh, timeTotal, scaledDutyCycle repeat waitpeq(|< SMT16030_PIN, |< SMT16030_PIN, 0) ' wait for pin to go high waitpeq(0, |< SMT16030_PIN, 0) ' wait for pin to go low startLow := cnt ' record start of low time waitpeq(|< SMT16030_PIN, |< SMT16030_PIN, 0) ' wait for pin to go high startHigh := cnt ' record start of high time waitpeq(0, |< SMT16030_PIN, 0) ' wait for pin to go low again endTime := cnt ' record start of low time timeTotal := endTime - startLow timeHigh := endTime - startHigh scaledDutyCycle := (timeHigh * SCALED_MULTIPLIER) / timeTotal scaledTemperature := ((scaledDutyCycle - SCALED_CONVERSION_SUBTRACTION) * SCALED_MULTIPLIER) / { } SCALED_CONVERSION_DENOMINATOR Pst.Home Pst.Str(string(" SMT16030 Temperture Sensor Demo", 11, 13)) Pst.Str(string(11, 13, "timeTotal = ")) ' 11 clears the end of the previous line, 13 moves to a new line Pst.Dec(timeTotal) Pst.Str(string(" clocks or ")) Pst.Dec(timeTotal / US_001) Pst.Str(string(" us")) Pst.Str(string(11, 13, "timeHigh = ")) Pst.Dec(timeHigh) Pst.Str(string(" clocks or ")) Pst.Dec(timeHigh / US_001) Pst.Str(string(" us")) Pst.Str(string(11, 13, "duty cycle (out of 1.0) = ")) DecPoint(scaledDutyCycle, SCALED_DECIMAL_PLACES) Pst.Str(string(11, 13, "temperature = ")) DecPoint(scaledTemperature, SCALED_DECIMAL_PLACES) Pst.Str(string(" C")) PUB DecPoint(value, decimalPlaces) | localBuffer[4] result := Format.FDec(@localBuffer, value, decimalPlaces + 3, decimalPlaces) byte[result] := 0 Pst.str(@localBuffer)It compiles but it's untested. I don't have a sensor to test it with.
Make sure and take a look at page 222 of the Propeller Manual to see how to use waitpeq. I think I used it correctly but I don't use waitpeq in Spin often.
I used scaled integer math. I think all the values stay safely below the 32-bit overflow but I could be wrong.
If you try the code, I hope you post the output. When posting output, it helps if you use code tags. Click "Reply With Quote" to see how I used code tags with the above code, and use the same tags when posting code or output from the PST.
The code could be greatly improved by taking multiple readings and averaging the readings.
Edit: I just noticed I left some comments from a previous project in the program. I deleted these comments from the forum code but the attached code still has these extra comments.
This is way more than I expected to get. I think I have time to test this on next weekend. I will let you know is this working or not!
