What does the "E" signify in a resistor value e.g. 470E — Parallax Forums
edited 2015-05-08 07:10 in General Discussion
I was looking into CD4027 circuit schematics and saw a resistor specified as "470E"
http://www.electronicshub.org/jk-flip-flop-using-cd4027/
What does the "E" mean? Tolerance?
Ron
    edited 2015-05-05 10:17
    I've seen it a few times and thought initially it was incidental font substitution from the Greek Omega symbol. (In Windows, the usual substitution is to the letter W, because of the way the Symbol font maps to the ASCII character set.) But it occurs often enough that I gather it's an alternative for R, as in 4E7 or 4R7 meaning to us Yanks 4.7k ohm. The E might pertain to the "E-series" of standard resistor values.
    edited 2015-05-05 11:14
    Very interesting, I Googled this: http://www.resistorguide.com/resistor-values/
    E6, E12, E24, etc...
    edited 2015-05-05 11:16
    Maybe 470E is hexadecimal. :) Or perhaps the schematic was drawn in Basque country. Where we would use the suffix "R" for resistance, in Basque it's erresistentzia, so they would naturally use an "E." Or ... I just don't have a clue.
  • Ding-BattyDing-Batty Posts: 302
    edited 2015-05-05 11:22
    According to what I read, it looks like the "E" fulfills the same purpose as the "R" in 470R == 470E, 0E22 == 0R22 (for 0.22 Ohm resistor). Resistors on AliExpress are sometimes listed with both values. It is not a tolerance value, because "E" is not one of the tolerance letters in use.
    edited 2015-05-05 11:26
    Thanks for that, Erco.
    Somehow, over the many years involved with things elektronik, I either never took the time to research the "E". Now I know why 1% metal film resistors are segregated as they are.
    I learned something today. :thumb:
    edited 2015-05-05 11:29
    I found that site as well but it really didn't spell it out. If it was E12 I would have expected it to say 470 E12 rather than just 470E.
    Still haven't found an exact description/explanation...
  • idbruceidbruce Posts: 6,197
    E = Enot = Ohms or that is what the web says
    edited 2015-05-05 11:35
    edited 2015-05-05 11:41
    Ron
    Yes, Enot, but I read that it is more specifically used for Iskra brand resistors
  • Mark_TMark_T Posts: 1,981
    edited 2015-05-07 07:31
    The E key is next to the R key on the qwerty kbd...
    edited 2015-05-07 09:03
    Mark_T wrote: »
    So you think it may be a typing error?
    kwinn wrote: »
    Well there are at least two other mistakes(*) in that circuit, I wouldn't be surprised.
    (*)No decoupling, push-switch crowbars the supply
