Gear plugin confusion - plugin scripts and Gear are both C# !
As a C# novice I find it very confusing that Gear itself is written in C#, and the plugin "scripts" are also in C#.
I've started to read the source code to try and understand which classes are used internally by Gear, and which are exposed and therefore useable
by the plugin "scripts".
Any hints / tips on this are appreciated !
E.g. I just tried to add :
The type or namespace name 'Propeller' does not exist in the namespace 'Gear' (are you missing an assembly reference)
But in AssemblyRegisters.cs the entry is there :
While the same plugin XML (Terminal.xml) has :
(namespace Gear.EmulationCore) is in PropellerCPU.cs)
using Gear.Propeller;to a plugin, and the Gear/CheckCode says :
namespace Gear.Propeller
using Gear.EmulationCore;, which is accepted by Gear/CheckCode.
Well inside the hook of GEAR, there are a lot of (confusing at first) things! :-)
See the post in "SIDcog - The sound of the Commodore 64 ! (Now in the OBEX)" thread (http://forums.parallax.com/showthread.php/118285-SIDcog-The-sound-of-the-Commodore-64-!-%28Now-in-the-OBEX%29?p=1327988#post1327988) and "Improved GEAR Emulator" http://forums.parallax.com/showthread.php/156347-Improved-GEAR-Emulator thread.
If you post your questions on plugins in one thread could be easier to answer them. ;-)
Antonio
