ATMEL capacitive touch breakout boards
https://learn.adafruit.com/adafruit-capacitive-touch-sensor-breakouts
Adafruit has some nice capacitive touch sensors - a momentary, a toggle, and a 5-Pad Momentary
The Momentary version can be configured for "Fast" mode (default) or low-power mode. Fast mode requires 0.5mA. Low Power mode requires just 50uA.
By default, the toggle sensor is configured for infinte time-out. it will stay on until you touch the sensor to turn it off.
It also supports a configurable time-out to turn off the output automatically after a delay.
To select this mode, cut the 'TIMER' jumper and connect a resistor & capacitor to the TIME pin.
Cheap on Ebay: http://www.ebay.com/itm/1x-XD-34-TTP224-4-Way-Capacitive-Touch-Switch-Digital-Sensor-Module-Board-Plate-/390977396193
My best use of cap sensors yet: https://www.youtube.com/watch?v=3e92B8JNNns
I also like the looks of this one on Futurlec - uses the IQS127D
Two digital outputs are provided, one for Touch and the other for Proximity
http://www.futurlec.com/Touch_Pad.shtml
When behind a plastic project enclosure box, a firm press works.
I am pleased with how well they work.
"Another" processor I used in the video in post #2 has integral touch sensing capability on 11 of its GPIO pins. A built-in function reads the field on an attached plate, pad or wire and returns a number. With calibration, you could also determine proximity vs touch. Not bad for a $4 chip.
The single pad (momentary and toggle) have an LED which shows through a hole in the PCB. A trace can be cut disabling the LED if desired,
While the board detects proximity as well as touch, there is only one output pin which reflects either/both.
I will probably use a toggle sensor with the Sharp 8A solid state relay (which Parallax sells) to create a table lamp touch switch. Very low current draw - 3 AAA batteries should last quite a while.
Add a 4.5V (3 AA cell) battery and a 220 ohm resistor and you've got a touch sensitive 125VAC switch.
Draws about 15.6 milliamps (or 8 milliamps at 3V) when turned on.
Or for $1.09 free ship: http://www.ebay.com/itm/1-Way-Touch-Control-Sensor-Table-light-Parts-On-off-Bulb-Lamp-Switch/261489643788
Hmmm - says 50Hz - not 60Hz. Wonder it works in U.S. Wiring diagram hard to read. Great deal if it works here!
http://www.answers.com/Q/What_is_50hz_and_60hz
I guess you ordered one/some...
Also says AC 220V +/- 10% - think this is for Europe, etc
This seller has one opened up - circuit looks unsubstantial - I guess the flat. vertical thing is a triac
http://www.ebay.com/itm/Table-light-Parts-On-off-1-Way-Touch-Control-Sensor-Bulb-lamp-Switch-Black-/121347212401?pt=LH_DefaultDomain_0&hash=item1c40db8471
This one sells 110V or 220V - except they are 3-way AND
- http://www.ebay.com/itm/1Pc-AC-110V-220V-Table-Desk-light-3-Way-Touch-Control-Sensor-lamp-Switch-S7-/321624234794?pt=LH_DefaultDomain_0&var=&hash=item4ae24c5b2a
Almost every bulb in my house is LED. Philips has a nice 40/60/100 3-Way LED now http://www.homedepot.com/p/Philips-40-60-100W-Equivalent-Soft-White-2700K-3-Way-A21-LED-Light-Bulb-453340/205427985
Bought one - like to get more
Arrived today and it works fine on 120VAC/60hz. No wiring diagram included, but I took a closer look at the original listing. The photo shows hookup details etched in the black plastic case, which mine didn't have. The photo was also reversed and required flipping and zooming in to read, but it worked fine. Black wire is common, to 120VAC and the light bulb. Red wire to other 120VAC connection. White wire to other bulb connection. Yellow wire is touch sensor, connect to any metal object. It worked when I just touched the brass wire connector. A closer look at the photo and is says 120V/240V and 50hz/60hz. Not sure what "+/-10%" brings to the party.
It's for incandescent bulbs, obviously. I did a quick test with a CCFL which didn't work. I almost tested with my one LED bulb but I chickened out.
I'll buy that for a dollar! (Robocop)
All of my table lamps are LEDs so I guess I'll pass.
- Ron
Anyone have any input about potential damage? Or maybe the performance will just suffer since the current levels are so low?
