TTP223-BA6 touch pad detector IC
Has anyone experimented with these touch sensors?
EDIT: I found erco's post with for the TTP226 / 8 pad board: http://forums.parallax.com/showthread.php/156497-2.79-8-Channel-Capacitive-Keypad
There are various boards on eBay and elsewhere.
I was thinking about making a touch sensitive lamp module and found several circuits using 555 timers (with or without a flip-flop) and then came across these sensors.
I may order a few just to play around with...
http://www.ebay.com/itm/Touch-Sensor-Capacitive-Touch-Switch-Module-DIY-for-Arduino-Digital-TTP223B-/261758997611?pt=LH_DefaultDomain_0&hash=item3cf20d546b
Datasheet: http://www.datasheet4u.com/download.php?id=770045
They are momentary - they work as proximity sensors but your finger needs to be real close (like 1/16th inch). Not bad for $1.24.
