TouchOSC on the Prop
MJHanagan
TouchOSC is a very simple app for the iPhone that utilizes WiFi to communicate with other devices on the same local network, It seems like this would be a very convenient way to communicate with the Propeller outfitted with an Xbee WiFi module. I found this forum entry but none of the links seem to work: http://forums.parallax.com/showthread.php/134273-PropOSC-Open-Sound-Control
Has any one looked into this and perhaps has some Prop code they could share?
http://obex.parallax.com/object/670
I think that was the Object he was hacking.
Also see:
http://forums.parallax.com/showthread.php/158057-OSC-Open-Sound-Control
Yes, please. I would like to see how this OSC works with the Propeller. Thank you.
UPDATED: Fixed bug having to do with 32bit padding, or lack there of.
I'm noticing a couple of bugs with this version that need working out around 32 bit alignment padding. I will try to nail them down and post and updated version.
Fixed that issue, let me know if you find any others.
