ESC Beep Troubleshooting Guide
I almost have my ELEV-8 v2 ready to fly, but I found out I'm not as tech savvy as I originally thought.
I have individually plugged each ESC/motor into the throttle channel of the receiver and successfully ran them. Now that I have plugged the ESCs and the receiver outputs into the hoverfly board I need to sync the ESCs. I put the transmitter on full throttle, the ESCs beeped twice, throttled all the way down, and then instead of a long beep, the ESCs beeped three times, paused, beeped once, and then the flight controller beeped twice.
Additional Info:
- I flashed the flight controller with version 2.0 of the software.
- I have never used a 'fancy' transmitter before - so the problem could easily lie there.
- I have a FlySky FS-T6 transmitter - I wasn't sure if the switch for the 5th channel should be on or off, so I tried it both ways.
Thanks for any help!
Additional Info:
https://www.parallax.com/sites/default/files/downloads/80000-ELEV-8-Quadcopter-Info-Assembly-Guide-v1.1_0.pdf
Page 18
The version 1 and 2 Hoverfly board are the same and run the same firmware.
What color is the LED on the Hoverfly board after the startup sequence?
They are the same controller board, and should respond the same.
I never got my version 2 to this stage, as I had an ESC smoke on first power up. I have been waiting for the snow to go away before finishing it up. I'll have both running this weekend if you want to compare notes.
BTW, Welcome to the forums!
Jim
Make sure you have did a good Bind between the transmitter and receiver.
I have a Spectrum DX6, and I have my Gain on channel 5. If I turn on my transmitter, it complains "Gear Switch Position Zero". This is to remind me that the Gain is in the correct position, but I have to turn that switch off, then on for the Transmitter to begin transmitting. This procedure was not show in the video.
Thanks for the help!
Now a video of your flights.
Jim
