IR Line follower Wiring
Trying to wire up the IR line follower kit on the Boebot. I can figure out P0 thru P7. I can't figure out how wire the black red white wires. any help would be appreciated.
thank you.
thank you.
https://www.parallax.com/sites/default/files/downloads/28034-Infrared-Line-Follower-Documentation.pdf
Black should connect to Pin 1 on the Line Follower board, Red Pin 2, White Pin 3. The other end should plug into the X4 connector on the BOE at PIN 14. Black will be towards the bottom, (breadboard area).
