Quickstart and Linux: FTDI FT231x vs FT232R — Parallax Forums
prof_brainoprof_braino Posts: 4,313
edited 2015-04-13 16:17 in Propeller 1
I'm talking to a quickstart using minicom terminal program.
Quickstart boards rev A with FTDI FT232R USB UART [0600] work as always.
Quickstart boards rev B with FT231X USB UART [1000] will display as normal, but do not respond to terminal input. The quickstart LEDs don't even flash.
What am I doing wrong? Do I have to create a lockfile or something? Is this something to do with running a 64 bit linux instead of 32 bit?
Thanks!
Answer 1 - if minicom worked with Quickstart Rev A but not with Rev B:
sudo minicom /dev/ttyUSB0
ctl^a z o (cOnfigure)
serial port setup
F - Hardware Flow Control : No
G - Software Flow Control : No
The sudo here allows saving the default configuration file.
Answer 2 - if minicom won't start and gives a permissions error :
sudo addgroup $USERNAME dialout
  • jmgjmg Posts: 15,198
    edited 2015-04-12 15:47
    FT231X is a newer device, so what drivers are you using, and what does FTDI say about support ?
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2015-04-12 15:57
    About 10 months ago I had a similar issue ... the FTDI enumerated to a COM port, but I think the other enumerated to a DEV. I was able to find a hack work around after extensive digging, At the time I just needed to open a communication COM port and ended up using a terminal program I found that was able to circumvent the problem.
    What does the command below return? when the Board is connected versus when it is removed? Does it show evaluating as a COM port or something different?
    dmesg | grep attached
    You might also need to chmod the attached device ....
    i.e.
    If my USB enumerated to /dev/ttyUSB0 then .....
    For proper permissions you may need to chmod /dev/ttyUSB0 for READ on some systems as a root user.
    edited 2015-04-12 16:01
    Figured out the change. Need to turn off Hardware Flow Control and turn off Software flow control
    serial port setup
    save as default. minicom now responds as before.
    I think the difference is the FT231x supports DTR, and the FT232R uses ...?
  • ElectrodudeElectrodude Posts: 1,684
    edited 2015-04-12 21:48
    @prof_braino:
    If you add yourself to group uucp (or whatever the group of /dev/ttyUSB0 is, obtained by ls -l /dev/ttyUSB0), you won't need sudo:
    sudo gpasswd -a $USER uucp
    edited 2015-04-13 15:57
    jmg wrote: »
    I'm using the standard drivers that come with linux by default. No additional driver installation is needed (so far).
    edited 2015-04-13 16:04
    ~ $ dmesg | grep attached
    [   62.609183] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [  155.549327] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [  183.444967] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [  344.832241] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [  371.225712] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [  400.160612] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 1138.455135] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 1225.994409] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 2219.999567] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 2283.024746] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3322.676767] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3444.999598] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3662.199721] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3688.443995] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3718.954926] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3765.936505] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3783.163717] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 3945.230993] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 4422.154891] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    [79301.111329] usb 3-8: FTDI USB Serial Device converter now attached to ttyUSB0
    Same whether connected or removed.
    edited 2015-04-13 16:05
    You might also need to chmod the attached device ....i.e. If my USB enumerated to /dev/ttyUSB0 then .....
     ~ $ ls -alF /dev/ttyUSB0
    crw-rw---- 1 root dialout 188, 0 Apr 13 18:06 /dev/ttyUSB0
    So these premissions need Read added to Group and everyone?
    @prof_braino:
    On Ubuntu/Mint, the group is dialout; and I did:
     ~ $ groups
    username adm dialout cdrom sudo dip plugdev lpadmin sambashare vboxusers
    I've not seen the gpasswd command in the context of fixes to /dev/ttyUSB0. Is gpasswd doing the same as addgroup, or is there another permission involved?
