Water level measurement.
I have a boat with 2 fresh water tanks. I would like to measure the level of the tanks using a non invasive method such as capacitive sensors mounted on the outside of the tanks. Any one out there that has done this. The tanks are non metalic.
https://www.parallax.com/catalog/sensors/pressureflexrpm
This sounds like something that I could use on my solar boat to sense heel and pitch angles without having any external components. I'd like to know more about it. Can you point me to any examples?
I'm sure this method has come up DIY before here and elsewhere, but I can't put my url on it right now. My own experience with this has been with stream level and tidal monitoring. That uses a metal tube with a teflon insulated wire running down the center. The capacitor is formed across the insulation of the wire. They work okay, but not great accuracy. As the wire becomes coated with crud it forms a spurious conductive path and makes it seem like the water is deeper than it actually is. (salt especially on a marine tide gage) It is good for maybe 1% or 2% of repeatability.
External components? You mean a sensor inside the hull only?
Yes, this is the part I don't quite understand. You said; "You might try two wide strips of adhesive-backed metal tape on the outside of the tank". Maybe that was a typo. If both strips are on the side opposite the liquid, how does it work?
metalStrip#1 ---- plasticInsulation ---- water ---- plasticInsulation ---- metalStrip#2
The electrical connection is made to strip#1 and strip#2. The water acts as an intermediate conductor, not as a dielectric.
It is a sliding plate in relation the the strips. The strips should probably be wide relative to the thickness of the hull or tank wall.
I did find this commercial application...
https://garnetinstruments.com/rv-shop/
