Basic Stamp Activity
Greeting everyone, I am in a bit of a conundrum. Basically I have been tasked with something that’s definitely not one of my strong suites. I only know the basics of programming and now I am seriously stuck. I am hoping someone could help give me a little nudge in the right direction with writing this code. I’ve been tasked with writing a code to make microcontroller do the following using the Basic Stamp Activity Kit:
Use the following devices as specified:
Pushbutton on P2 (PB1)
An active-high LED on P5 (LED1)
Buzzer/speaker on P8 (BUZZER)
Program the controller to perform the following:
1.On start, sound the speaker at 3000 Hz for 1 second.
2.Wait until the button is pressed.
3.Once pressed:
4.Blink LED1 on for 100mS.
5.Sound the buzzer at 3000 Hz for 100 mS
6.Turn LED1 off.
7.Count up by 1 with a variable (once per press)
8.Display the count value in the DEBUG Window.
9.Wait until the button is released.
10.If the count is equal to 10:
11.Sound buzzer at 4000Hz for 1 second
12.Reset the count to 0.
13.Repeat the program from step 2.
So far this is the code that I have written:
3.Once pressed:
6.Turn LED1 off.
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
FOR counter = 1 TO 10
DEBUG ? counter 'Display the variable of counter in DEBUG Window
PAUSE 1000 'Pause before circuit startup
FREQOUT 8, 1000, 3000 'Sound piezo at 3000Hz for 1 SECOND
DO
DEBUG ? IN2
IF (IN2 = 1) THEN
HIGH 5
PAUSE 50
LOW 5
PAUSE 50
ELSE
PAUSE 100
ENDIF
FREQOUT 8, 100, 3000 'Sound piezo at 3000Hz for 100mS
FREQOUT 8, 1000, 4000 'Sound piezo at 4000Hz for 1 sec
This should help you with the button since the BASIC Stamp Manual doesn't show this example for the DO...LOOP
DO : LOOP UNTIL (Put the condition that you are waiting for in here)
Are you sure the buzzer is beeped for a count of 10 AFTER the button is released?
https://www.parallax.com/sites/default/files/downloads/27218-Web-BASICStampManual-v2.2.pdf
DO...LOOP - Page 179 of PDF
IF...THEN - Page 235 of PDF
I highly suggest that you use Constants and Directives as shown starting on page 160.
It's also very good practice to comment your programs such as the one on page 299.
https://www.parallax.com/sites/default/files/downloads/28123-Whats-a-Micro-v3.0.pdf
' {$STAMP BS2} ' {$PBASIC 2.5} PAUSE 1000 'PAUSE 1 SECOND BEFORE CIRCUIT STARTUP FREQOUT 8, 1000, 3000 'SOUND PIEZO AT 3000Hz FOR 1 SECOND DEBUG "DEPRESS PUSHBUTTON",CR 'INSTRUCTS OPERATOR TO DEPRESS PUSHBUTTON counter VAR Nib 'WILL COUNT NUMBERS FROM 0-15 FOR counter = 1 TO 10 COUNTER = 0 'STARTS COUNTER AT ZERO DO 'BEGINS MAIN LOOP DO 'BEGIN NESTED LOOP LOOP UNTIL IN2 = 1 'BREAK OUT OF MAIN LOOP WHEN I/O PIN 2 (PB1) IS HIGH IF (IN2 = 1) THEN 'ONCE PUSHBUTTON IS DEPRESSED, BLINK LED1 FOR 100 MILLISECONDS HIGH 5 'ILLUMINATES LED ON P5 (LED1) PAUSE 50 LOW 5 'DE-ENERGIZES LED ON P5 (LED1) PAUSE 50 FREQOUT 8, 100, 3000 'SOUND PIEZO AT 3000HZ FOR 100 MILLISECONDS LOOP UNTIL (IN2 = 0) LOW 5 'TURNS LED1 OFF COUNTER = COUNTER+1 'ADDS 1 TO COUNTER(?) DEBUG ? counter 'DISPLAY THE VARIABLE OF COUNTER IN DEBUG WINDOW DO IF IN2 = 1) THEN, DEBUG "RELEASE PUSHBUTTON",CR 'INSTRUCTS OPERATOR TO RELEASE PUSHBUTTON IF DEPRESSED ELSEIF (TIMECOUNTER = 10) THEN 'STOPS LOOP WHEN COUNTER REACHES 10 NEXT FREQOUT 8, 1000, 4000 'SOUND PIEZO AT 4000HZ FOR 1 SEC LOOP ENDIF
The 1 second PAUSE gives the computer time to prepare for BS2 serial communication.
Variables are usually declared first.
When would Counter change if you used FOR...NEXT?
What's wrong with DEBUG paced BEFORE the main DO...LOOP?
You make Counter = 0 but FOR...NEXT started it with 1.
Which LOOP goes with which DO and what is it there for?
What does Step 4 tell you to do?
There is a LOOP UNTIL (IN2 = 0) but what Step is this?
Are you or is FOR...NEXT in control of Counter?
Might this DO...LOOP after DEBUG Counter be a problem?
Where should Step 9 be?
What variable is TimeCounter?
How does FOR...NEXT work again and what happens to anything after NEXT?
What are LOOP and ENDIF connected to and are they in the correct order?
' {$STAMP BS2} ' {$PBASIC 2.5} counter VAR Byte 'DECLARES VARIABLE TO COUNT (0-255) PAUSE 1000 'PAUSE 1 SECOND BEFORE CIRCUIT STARTUP FREQOUT 8, 1000, 3000 'SOUND PIEZO AT 3000Hz FOR 1 SECOND PAUSE 500 'PAUSE 1/2 SECOND MAIN: DO 'STARTS MAIN LOOP COUNTER = 0 'STARTS COUNTER AT ZERO DO 'STARTS NESTED LOOP LOOP UNTIL IN2 = 1 'CONTINUE MAIN LOOP UNTIL PB1; HIGH I/O PIN 2 IF (IN2 = 1) THEN 'ONCE P/B IS DEPRESSED, BLINK LED1 FOR 100 MILLISECONDS COUNTER = COUNTER +1 'ADDS 1 TO COUNTER VARIABLE HIGH 5 'ILLUMINATES LED ON P5 (LED1) PAUSE 100 LOW 5 'DE-ENERGIZES LED ON P5 (LED1) PAUSE 100 FREQOUT 8, 100, 3000 'SOUND PIEZO AT 3000HZ FOR 100 MILLISECONDS ELSE THEN GOTO MAIN LOOP UNTIL IN2 = 0 'LOOPS NESTED LOOP UNTIL P/B RELEASED DO IF COUNTER = 10 THEN 'WHEN COUNTER REACHES 10 FREQOUT 8, 1000, 4000 'SOUND PIEZO AT 4000HZ FOR 1 SEC ENDIF DEBUG ? counter 'DISPLAY THE VARIABLE OF COUNTER IN DEBUG WINDOW LOOP 'RETURNS TO MAIN LOOP AWAITING HIGH ON PB1
' {$STAMP BS2} ' {$PBASIC 2.5} ' Variable Declaration counter VAR Byte 'DECLARES VARIABLE TO COUNT (0-255) ' Initialization PAUSE 1000 'PAUSE 1 SECOND BEFORE CIRCUIT STARTUP FREQOUT 8, 1000, 3000 'SOUND PIEZO AT 3000Hz FOR 1 SECOND (Step 1) PAUSE 500 'PAUSE 1/2 SECOND ' Main Loop MAIN: ' [Label - Main Subroutine] DO 'STARTS MAIN LOOP (Loops Forever) [Start of Main DO...LOOP] COUNTER = 0 'STARTS COUNTER AT ZERO (Step 12) DO 'STARTS NESTED LOOP [Begin Inner Loop #1] LOOP UNTIL (IN2 = 1) 'CONTINUE MAIN LOOP UNTIL PB1; HIGH I/O PIN 2 (Step 2) [End Inner Loop #1] IF (IN2 = 1) THEN 'ONCE P/B IS DEPRESSED, BLINK LED1 FOR 100 MILLISECONDS (Step 3) [Start of IF #1] COUNTER = COUNTER +1 'ADDS 1 TO COUNTER VARIABLE (Step 7) HIGH 5 'ILLUMINATES LED ON P5 (LED1) [Step 4] PAUSE 100 ' (Wait 1/10 second) LOW 5 'DE-ENERGIZES LED ON P5 (LED1) [Step 6] PAUSE 100 ' (Wait 1/10 second) FREQOUT 8, 100, 3000 'SOUND PIEZO AT 3000HZ FOR 100 MILLISECONDS (Step 5) ELSE THEN GOTO MAIN ' [End of IF #1] LOOP UNTIL (IN2 = 0) 'LOOPS NESTED LOOP UNTIL P/B RELEASED (Step 9) [End of Inner Loop #2] DO ' [Start of Inner Loop #2] IF COUNTER = 10 THEN 'WHEN COUNTER REACHES 10 (Step 10) [Start of IF #2] FREQOUT 8, 1000, 4000 'SOUND PIEZO AT 4000HZ FOR 1 SEC (Step 11) ENDIF ' [End of IF #2] DEBUG ? counter 'DISPLAY THE VARIABLE OF COUNTER IN DEBUG WINDOW (Step 8) LOOP 'RETURNS TO MAIN LOOP AWAITING HIGH ON PB1 (Step 13) [End of Main DO...LOOP]
Notice the Outer Main DO...LOOP?
This loop will repeat forever unless you so your GOTO MAIN won't function. Besides it's bad practice to do that.
Counter = 0 will run everytime the loop repeats since you made it the first command. How does that affect the value of Counter?
What do you notice about Inner Loop #1 and the IF statement just below it?
That long IF...THEN...ELSE is missing an ENDIF at the end.
Many of your steps are out of order.
What does Step 4 say to do?
Inner Loop #2 is backwards.
Look again at what you program is doing and does it match what you were told to do?
If you don't understand a command of how a segment of code works then ask.
Good Indenting and Commenting make a program easier to read and understand.
I just needed to filter out all the noise.
Actually, you should credit Mr. Green since I learned the basic technique from him.
