We have a problem with our robot running our code
We have been working on a maze solving robot for s ometime. Recently though, the robot seemingly refuses to follow what we write, and also seems to skip to other functions while it is still running functions. I was wondering if we could get some help on this. The code will be listed below.
#include "simpletools.h"
#include "ping.h"
#include "abdrive.h"
int sizeOfMaze = 0;
int positionx = 0; //Bunch of variables (position of the robot in the x axis)
int positiony = 0; //position of the robot in the y axis
int orientation = 1; //cardinal direction of robot
int donechecking = 0;
int big = 0;
int finished = 0;
orientation:
1 = foreward
2 = facing right
3 = facing backwards
4 = facing left
int leftcheck = 0; //variables for checking which walls are there are which ones aren't
int rightcheck = 0;
int frontcheck = 0;
1 = increase positionx
2 = increase positiony
3 = decrease positionx
4 = decrease positiony
int pathing[500];
1 = left turn
2 = forward
3 = right turn
int num = 0;
void leftDegreeTurn(void) //90 degree turning code
high(26);
drive_goto(-29,-29);
drive_speed(0,0);
drive_speed(6, 27);
pause(2475);
drive_speed(0,0);
drive_ramp(-20,-20);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation == 1) //changing orientation for a left turn (needs polishing)
orientation = 4;
if(orientation = 2)
orientation = 1;
if(orientation = 3)
orientation = 2;
if(orientation = 4)
orientation = 3;
void rightDegreeTurn(void)
high(26);
drive_speed(0,0);
drive_speed(27, 6);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation = 1) //changing orientation for a right turn (needs position)
orientation = 2;
if(orientation = 2)
orientation = 3;
if(orientation = 3)
orientation = 4;
if(orientation = 4)
orientation = 1;
void moveForward(void) //function for going foreward
drive_goto(55,55); //actually go forward
if(orientation = 1) //change in position
positionx += 1;
if(orientation = 3)
positionx -= 1;
void leftDegreeTurnBack() //function for turning backwards (used in function for escaping dead end)
high(26);
drive_goto(-29,-29);//BACK LEFT TURNchange orientation
drive_speed(0,0);
drive_speed(-6, -27);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation = 1)
orientation = 2;
if(orientation = 2)
orientation = 3;
if(orientation = 3)
orientation = 4;
if(orientation = 4)
orientation = 1;
void rightDegreeTurnBack() //BACK RIGHT TURN same as other turn just backwards (needs polishing)
high(26);
drive_speed(0,0);
drive_speed(-27, -6);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation = 1)
orientation = 4;
if(orientation = 2)
orientation = 1;
if(orientation = 3)
orientation = 2;
if(orientation = 4)
orientation = 3;
void moveBackward(void) //function for going backwards
drive_goto(-55,-55); //go backwards
positionx -= 1;
if(orientation = 3)
positionx += 1;
void backupFromDead(void) //fucntion for backing up through the maze
while(pathing[num] != 0)
low(26);
if(pathing[num] = 1)
rightDegreeTurnBack();
pathing[num] = 0;
num -= 1;
pause(1);
else if (pathing[num] = 2)
moveBackward();
pathing[num] = 0;
num -= 1;
pause(1);
else if (pathing[num] = 3)
leftDegreeTurnBack();
pathing[num] = 0;
num -= 1;
pause(1);
pathing[num] = 5;
void backThroughTheMaze() //function for going back through the maze after completing it the first time
while(positionx !=1)
if (pathing[num] = 1)
num -= 1;
pause(1);
moveBackward();
num -= 1;
pause(1);
num -= 1;
pause(1);
int main()
sizeOfMaze = 11;
if(big == 0)
moveForward();
pause(5);
big = 1;
pause(5);
while(positionx != sizeOfMaze) //while not at the end of the maze
if(ping_cm(8) < 6) //check for left wall
leftcheck = 1;
pause(5);
else
leftcheck = 0;
pause(5);
pause(5);
if(ping_cm(7) < 10) //check for forward wall
frontcheck = 1;
pause(5);
else
frontcheck = 0;
pause(5);
pause(5);
if(ping_cm(6) < 6) //check for right wall
rightcheck = 1;
pause(5);
else
rightcheck = 0;
pause(5);
pause(10);
/*if(leftcheck == 0 && frontcheck == 1 && rightcheck == 1)
leftDegreeTurn(); //left
pathing[num] = 1;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
if(leftcheck == 1 && frontcheck == 0 && rightcheck == 1)
moveForward(); //forward
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
if(leftcheck == 1 && frontcheck == 1 && rightcheck == 0)
rightDegreeTurn(); //right
pathing[num] = 3;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
/*if(leftcheck == 0 && frontcheck == 1 && rightcheck == 0)
leftDegreeTurn(); //left zero
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
if(leftcheck == 0 && frontcheck == 0 && rightcheck == 1)
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
if(leftcheck == 0 && frontcheck == 0 && rightcheck == 0)
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
if(leftcheck == 1 && frontcheck == 0 && rightcheck == 0)
moveForward(); //forward zero
pathing[num] = 2;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
pause(10);
if(leftcheck == 1 && frontcheck == 1 && rightcheck == 1) //if all walls are detected, go back
high(26);
backupFromDead(); //backup till latest zero
finished = 1;
backThroughTheMaze(); //fucntion for going back through the maze
pause(100); //wait a bit
if(finished = 1)
num = 1;
if (pathing[num] = 1) //final runthrough which doesn't need a function
leftDegreeTurn();
pause(5);
num += 1;
pause(5);
moveForward();
pause(5);
num += 1;
pause(5);
rightDegreeTurn();
pause(5);
num += 1;
pause(5);
Any help would be appreciated. Thank you.
#include "ping.h"
int sizeOfMaze = 0;
int big = 0;
int finished = 0;
orientation:
1 = foreward
2 = facing right
4 = facing left
int rightcheck = 0;
int frontcheck = 0;
int pathing[500];
1 = left turn
2 = forward
3 = right turn
int num = 0;
high(26);
drive_speed(0,0);
drive_speed(6, 27);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
orientation = 4;
if(orientation = 2)
orientation = 1;
if(orientation = 3)
orientation = 2;
if(orientation = 4)
orientation = 3;
high(26);
drive_speed(0,0);
drive_speed(27, 6);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
orientation = 2;
if(orientation = 2)
orientation = 3;
if(orientation = 3)
orientation = 4;
if(orientation = 4)
orientation = 1;
positionx += 1;
if(orientation = 3)
positionx -= 1;
high(26);
drive_speed(0,0);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation = 1)
orientation = 2;
if(orientation = 2)
orientation = 3;
if(orientation = 3)
orientation = 4;
if(orientation = 4)
orientation = 1;
high(26);
drive_speed(0,0);
pause(2475);
drive_speed(0,0);
pause(1000);
drive_speed(0,0);
low(26);
if(orientation = 1)
orientation = 4;
if(orientation = 2)
orientation = 1;
if(orientation = 3)
orientation = 2;
if(orientation = 4)
orientation = 3;
positionx -= 1;
if(orientation = 3)
positionx += 1;
low(26);
pathing[num] = 0;
num -= 1;
pause(1);
moveBackward();
pathing[num] = 0;
num -= 1;
pause(1);
pathing[num] = 0;
num -= 1;
pause(1);
pathing[num] = 5;
num -= 1;
pause(1);
moveBackward();
num -= 1;
pause(1);
num -= 1;
pause(1);
int main()
sizeOfMaze = 11;
if(big == 0)
moveForward();
pause(5);
big = 1;
pause(5);
leftcheck = 1;
pause(5);
else
leftcheck = 0;
pause(5);
pause(5);
frontcheck = 1;
pause(5);
else
frontcheck = 0;
pause(5);
pause(5);
rightcheck = 1;
pause(5);
else
rightcheck = 0;
pause(5);
pause(10);
pathing[num] = 1;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 3;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 1;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
moveForward();
pathing[num] = 2;
pause(5);
num += 1;
pause(10);
pathing[num] = 2;
pause(5);
num += 1;
pause(5);
pathing[num] = 0;
pause(5);
num += 1;
pause(10);
high(26);
finished = 1;
if(finished = 1)
num = 1;
leftDegreeTurn();
pause(5);
num += 1;
pause(5);
moveForward();
pause(5);
num += 1;
pause(5);
rightDegreeTurn();
pause(5);
num += 1;
pause(5);
I don't have much else to offer at this point. I'll take a look at the properly formatted code (in this post) and see if anything pops out.
I generally find microcontrollers are pretty code at following what the code says. They tend to do what we tell them to do, which doesn't always match what we want them to do.
Edit: Actually I'm having a hard time knowing what to look for. What were you expecting the robot to do? What did the robot do?
Just a suggestion to help shorten your source listing a little. When a single statement follows an IF(...) statement the curly braces aren't needed. Simply place the following line below the IF(...) statement. Such as the corrected snippet below:
Probably better to use the Switch-Case procedure instead. Something like...
This way orientation only changes once through the block.
