Upper case problem — Parallax Forums
Upper case problem
MoskogMoskog Posts: 556
edited 2015-04-06 11:41 in General Discussion
Can anyone help me solve this problem: when I type this Message a lot of Words starts With upper case letters even though I don't press the caps button or the caps Lock. Its a problem because I always have to og back and erase and retype what I Write. Its not so bad right now but sometimes its real bad.
Its so bad sometimes that I need to use another editor instead and paste the text here.
I'm using win8 and the problems are here in this forum only.
Hmmm.. not so bad right now when I'm asking for help!
  • cruXiblecruXible Posts: 78
    edited 2015-04-03 01:40
    Did you ever figure it out?
    What language is set to default in windows? Maybe it is not English, and assuming that the words are proper names and autocorrecting them?
  • MoskogMoskog Posts: 556
    edited 2015-04-03 04:05
    OK, Seems I can change to English Language but then I have to log off and log on again to make the change. I'm using Norwegian as default because of the Norwegian
    edited 2015-04-06 01:37
    Suddenly everything is normal again. I have no ide what I have done, but maybe the spell checking doesn't take action before a restart?
    cruXible wrote: »
    .....and assuming that the words are proper names and autocorrecting them?
    Seems like you are right!
    I had a similar problem a month or so back. Thought it might be the spell check dictionary so I added the words to it and the problem slowly disappeared.
