Are SimpleIDE Terminal's special codes working?
Good time!
Sample of C - code:
#include "simpletools.h" // Include simpletools
int main() // main function
while(1) // Endless loop
high(26); // Set P26 I/O pin high
print(BEEP); // Shoud it BEEP?
print("*");
pause(30); // Wait 1/10 second
low(26); // Set P26 I/O pin low
pause(970); // Wait another 1/10 second
But there are no sound. Other codes did not work too.
All functions in simple ide options are turned on. If show hexadecimal Input is turned on some codes are printed, but BEEP does nothing.
What I'm doing wrong?
Sample of C - code:
print("*");
You need to use the "run with terminal" option from SimpleIDE.
On my computer I get the windows 'dunk' sound (windows defaultbeep) 10 times.
Note that with Propeller C you can use the "printi()" function instead of "print()" and save about 4k bytes, as long as you are not printing a floating point number.
Hope this helps
Tom
Tom
