Voltage amps power and current - I think I might not know what it is I don't know
OK I think I'm starting to understand Voltage and current a little but I still have this uneasy feeling that it is as clear as mud to me. I switched one of my robots from the BOE to a homework board so he is less expensive. I use this one at work where other people can bump into him and I take him back and forth where I have dropped him once. The problem I have is that the homework board with this surface mount chip only operates on a nine volt battery that last all of about fifteen minutes before he resets. I solved this reset problem on the BOE by going to rechargeables but 9v rechargeables are hard to find and expensive. Will he run without killing him if I run him on 7 rechargeable AAs. This would give him 8.4V and a lot more miliamp hours. Will it fry him though? Or is the 0.6V decline going to just not work?
Are you running the PIR off of VDD (5 volts), or VIN (whatever the input voltage is)? The version A of the PIR will work up to 5.0 volts, and the version B will go up to 6.0 volts.
The PIR would not like 7.2 or 9 volts if you run it from VIN.
Vdd and it is version B with the jumper set for 15 feet.
