Ping))) sensor
Has anyone done any studies into the efficacy of mounting the transducers side-by-side versus vertical? It seems to me that if they shared the same vertical axis, they'd be better at detecting smaller vertical objects in front of them like table and chair legs.
Please don't chastise me too much.
What I'm curious about is more like how the echoes would be different:
| TX > | O | <- this is a wall RX < | |
... versus...| | T/RX >< O | (TX / RX transducers vertical) | |
If off-center, would the former or latter be more likely to detect the obstruction?
Now, if you are panning the Ping back and forth, a long thin object lying horizontal will reflect more echos back than if that same object were standing vertical. That is the object's orientation to the sweep, not the orientation to the Ping. Whether the Ping was mounted horizontally or vertically you should see the same echo values during the sweep.
Many Sharp IR distance sensors have a very asymmetrical detection zone. I've read several sources which suggest orienting Sharp IR sensors vertically rather than horizontally.
I mounted both the IR and Ping sensors in a vertical orientation on my robot used to test the Eddie firmware.
I mounted the Ping sensors vertically in order to keep them close to the IR sensors.
The effects at RF frequencies would probably be more pronounced than when compared to near audible frequencie
I think a bigger influence is how close the target is to other "noise" targets. For example, if the sensor is closer to the floor, more of the floor falls within the "chirp cone", which means the floor can cause readings that are "too close". This also applies to IR sensors. Its really all about "what else lies in the senor's 'chirp cone'?"
I think I'm going to get the sensor and do some experimentation, and graph some results.
