Want to experiment with FPGA. Suggestions? — Parallax Forums
cbmeekscbmeeks Posts: 634
edited 2015-03-12 10:13 in General Discussion
I bought the Mojo v3 (or whatever it's called) a while back. Before I realized it doesn't work on Mac (not easily, anyway).
I'm going to eventually get a "PC" but that's a while out.
I'm mostly interested in video/audio work (which brought me to Propeller). I have the Propeller QuickStart board and I LOVE it. Going to build some video circuits with it.
Anyway, I know true, hard-core video work should be in FPGA. The things I want one day require the parallelism that FPGA offers. But I also realize that FPGA is hard. So I'm prepared for the long-haul of learning it.
But right out of the gate, there doesn't seem to be an easy to use system like Arduino or Propeller offer. With those, I can spend $20 - $50 and start building things within a few minutes.
With FPGA, it seems it's all about the tool chain, expensive licenses, and tons of different boards to use. Which all seem to be many hundreds of dollars. I'm just a hobbyist.
I've seen the Papilio (spelling?) but it doesn't seem to be very active.
What do you guys suggest? It would be great if it would work with my Mac and not take 60 gigs of space..lol.
  • LeonLeon Posts: 7,620
    edited 2015-03-12 08:00
    Unless you get a PC running Windows or Linux, you are probably stuck. Neither Xilinx or Altera support their tools on Macs. Free versions are available, supporting a limited range of chips, but they are both quite massive. If you are keen, get a Windows PC and download the free Altera Quartus II tools, and buy this low-cost Terasic FPGA board:
    http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=139&No=593
  • David BetzDavid Betz Posts: 14,516
    edited 2015-03-12 08:18
    Leon wrote: »
    I've successfully run the Altera tools under Windows 7 running in a VirtualBox VM on my Macintosh. Probably could do the same with the Linux version of the Altera tools running under Ubuntu on a VirtualBox VM.
    edited 2015-03-12 08:31
    I'd forgotten about that option for the Mac. I suppose that performance is OK now that Apple is using Intel processors in the Macs.
    edited 2015-03-12 08:32
    Leon wrote: »
    Yes, performance is pretty good since VirtualBox uses the virtualization hardware in the Intel processor.
  • cbmeekscbmeeks Posts: 634
    edited 2015-03-12 08:37
    Yeah, I was trying to avoid virtual machines since I am running a 2009 MBP. But I guess that's an option for now.
    Thanks for the suggestions. But, if I go the virtual machine route, I wonder if I just should use my Mojo V3. Spec wise, I'm not sure how it stacks up though. I just don't know enough about FPGA to know what you need to create video cards. LOL
    Thanks again.
    edited 2015-03-12 08:38
    cbmeeks wrote: »
    Thanks again.
    Or you could use this as an opportunity to upgrade your ancient Mac! :-)
    I'm thinking of doing that myself. My MacBook Pro is almost as old as yours.
    edited 2015-03-12 08:55
    Leon and David are correct, there are no native OSX tools but you can run either Windows or Linux versions on a Mac hosted VM.
    I'm currently (just started) playing with the Papilio DUO on my Mac running the Xilinx ISE using Win 7 on a Parallels VM. It works just fine. I've also run the Altera tools under similar conditions for the Parallax P1 and P2 FPGA images. I haven't tried a Linux VM yet since I had a copy of Windows.
    I've been told that the Windows versions of the FPGA tools are generally better supported and feature rich than the Linux versions at this time. Basic functionality is the same but some of the more leading edge or sophisticated features may be more advanced on the Windows versions - currently where the FPGA vendors have the most software revenue.
    As for Papilio, they may not seem active but Jack (the main guy) is very helpful and very active in development and support of his tools and boards. His DesignLab IDE is a very creative marriage of Xlinix ISE and the Arduino IDE which gives you a way to integrate FPGA designs using the Zpuino FPGA soft processor and Arduino sketches. The DUO also effectively has an Arduino Leonardo on the back in actual hardware so you can work on designs that complement the Arduino family without taking up the FPGA space to run a Zpuino.
    There is also a Papilio user that goes by the handle, Hamster who wrote a FPGA programming course that takes you from ground zero through some pretty sophisticated FPGA code using a Papilio One and their Logic Wing, I'm currently working through this course (slowly due to real world interruptions). You might want to start with the 500K Papilio One, to gain some experience and test out your tool chain on the OSX/Virtualbox/Linux set up. Once you have that under your belt, you can make some better informed decisions on a future path. By then, you may be ready for the Parallax 1-2-3 FPGA board and some virtual Propeller work.
    As far as the 60GB, I can't guarantee that! The FPGA tool suites are generally HUGE!!!
    Edit: There is also Digilent which makes/sells a number of FPGA dev boards. I have a couple of those that I haven't used much. They are very targeted toward university level FPGA classes and have good materials from what I've been exposed to. There boards are more expensive and less hobbyist oriented. Jack and the folks on the Papilio site are more hobbyist oriented in my opinion. Papillio also have some wings (shields/capes/hats) for their boards that may be interesting to your project goals.
    David Betz wrote: »
    Actually, I was wrong. I'm currently running the Altera tools under Ubuntu on a VirtualBox VM. That is all free software. Running Windows 7 under VirtualBox, of course, requires a Windows 7 license.
