Propeller ASC Board Vin advice. — Parallax Forums
ShawnaShawna Posts: 508
edited 2015-03-08 14:58 in Propeller 1
Hey guys,
I bought the propeller ASC Board. The overview page says Vin can be 6-9 Vdc. The shield I want to attach to it needs 12 volts DC to fire relays. Do you guys think I can run 12 VDC to Vin on the ASC board. It looks like the regulator is good for 20 volts input.
I want to try it but I don't want to blow up my 50 dollar board.
http://www.parallax.com/product/32214
Shawn
  • JonnyMacJonnyMac Posts: 9,202
    edited 2015-03-08 12:37
    I do it all the time -- but that's me. I live on the edge. :)
    The 5v regulator (L1117-5) may get a little warm, but 12v is within its input spec.
    edited 2015-03-08 12:45
    Very unlikely that you will damage the board, but as JonnyMac says the regulator may overheat. Sometimes they shut down/turn on several times a second causing weird behavior. Even this is not likely unless you are drawing fairly high current from the +5V regulator on the ASC board.
  • ShawnaShawna Posts: 508
    edited 2015-03-08 13:05
    Thanks guys I will give it a try.
  • WBA ConsultingWBA Consulting Posts: 2,935
    edited 2015-03-08 13:20
    Martin's wiki page for the Propeller ASC states 6-12 volts for Vin. My only concern would be how much current you will be pulling. The greater the voltage drop the 5v reg has to endure will equate to heat proportional to the current draw. If you need a lot of current out of the 5v reg, expect it to run hot, which could reduce its lifespan. http://mghdesigns.com/wiki/asc:start
    Edit: left this post as a draft for too long, so others beat me to the answer. I did start typing when no replies were posted, lol
    I have been running it at 12 volts for about the last hour. The regulator is not getting warm at all. I'm not really doing anything with it, just debugging my remote IO shield. I think it will be ok.
    Thanks again guys
    Shawn
