Help with a circuit using an AC adapter.
I'm designing a board for my propeller. At the moment, it's running fine off of D batteries but I also want to have the option of plugging into the wall using this. ( http://www.parallax.com/product/750-00009 ) My one question is, how do I wire the board so that if I use the wall-wart it doesn't drain the batteries? I also don't want the wall-wart to try and run current into the batteries because I'm pretty sure they don't like that... My theory was just to put a diode on both sources' anodes but I figured I'd ask here first. Thanks!
Your screen is dim, how many volts are going to it?
Sparks Fun documents say it needs 6 to seven volts.
Features:
Voltage: 6V – 7V DC
Current: 220mA (backlight at 100%)
Input: 0-5V, 115,200bps (adjustable), 8 data bits, 1 stop bit, no parity
5.4 volts * 220 ma = 1.1 watts
Can your diode handle 1.1 watts?
I'm starting a hexpod project, 20 or more servos! I should start posting it's progression the project forum.
You could put 5 diodes in parallel to take all that current.
