Testing 100 IC Sockets — Parallax Forums
ercoerco Posts: 20,257
edited 2015-03-06 11:29 in General Discussion
A silly diversion from today's valve cover gasket repair job. 100 sockets for $3.09 :)
    edited 2015-03-05 14:49
    ....what's the test method there Mr. Erco?
  • ercoerco Posts: 20,257
    edited 2015-03-05 15:11
    Just a quick way to verify all 8 pins had continuity though all those sockets: power, programming and driving 2 outputs. Not real scientific. :)
    edited 2015-03-05 15:27
    That's a nice Tower of Babel! :)
    Still nursing that cold? Get Better.
    edited 2015-03-05 15:43
    99 sockets to test 'til I'm done,
    99 sockets to test.
    Take one down,
    Check pins all around,
    98 sockets to test 'til I'm done.....
    edited 2015-03-05 15:47
    ...ohhhhhhhhh - I didn't see the chip in the top socket.
    Gotcha, understood.
    edited 2015-03-05 17:12
    Jim might be the only person (car guy) to appreciate the other thing I got excited about today replacing that valve cover gasket:
    I found out that my PT Snoozer has roller rockers. Between that, 4 valves per cylinder and dual overhead cams, it IS a hot rod!
    PS: Erco's "Leaning Tower of Sockets" has a nice ring to it, right?
    Great song Rick, I'll be singing that all day.
    edited 2015-03-06 00:23
    That ain't hot...
    My cast-aluminium engine with a 10:1 compression... using 95 Octane... That's hot.
    (Well, not any more, after I fixed the cooling... )
    edited 2015-03-06 08:20
    Valve cover gasket on horizontal opposed engines are even cooler when you have to lay on your back to change them. :)
    I wanted to put a roller crank in my 1850cc VW bug but, a 19 year old could not afford a $500 crank. I know you said rockers, but the crank would have been the cats meow back then.
    Roller crank on a V-Dub? Awesome sauce.
    Alas, my roller rockers do not a hot rod make, but they sure are tiny and cute. I like my motor better now. Feels good to get my hands dirty again. Maybe I need a bigger car project soon... (?)
    1008 x 605 - 299K
