I2C Nightmare: So what's wrong with ASC?
Hi all,
I found out that the sensors I have been working on are all fine. I used another propeller board (not ASC) and it works fine. (which also implies that I threw some well-working sensors!! my money!)
Anyways, then, this fact tells me that the reason why I2C didn't work for my ASC is not because of voltage out of propeller pins (which is 3.3v) nor data transmit rate. So,
what went wrong with the ASC chip? Is there any possible defect that ASC internally has? Or am I going with wroing logical direction to make this conclusion?
ie always have more than one means of verifying an item is working.
These 3.3K series resistors are recommended any time a Propeller is used with input signals that may exceed 3.3V and are recommended in some cases with Propeller I/O pins used as outputs (like servo motor signal lines). Similar resistors are built-in to the Propeller Activity Board and the Propeller Board of Education in the connections to the servo headers, so this is not a new idea.
You missed one. There are now three threads on this topic.
All the help offered in the previous threads is now unseen and people don't realize what fixes have already been suggested.
Reference:
http://mghdesigns.com/wiki/asc:start
